电子发烧友论坛|
您好,我在WinXP SP3中运行VEE 9.2(build 9.2.135122(2010年3月22日))。我想在Direct IO事务中关闭SCPI代码完成功能。我取消选中Advanced Instrument Properties中的SCPI XML Filename复选框
这似乎工作一次 - 一旦我遇到运行时错误等,设置会自动恢复为启用SCPI代码完成。是否有其他人有这个问题?我真的想要禁用SCPI代码完成 - 它甚至会导致 我键入的事务会被破坏,例如在事务中键入语法更改后更改格式并且更改丢失!!!!我是否有最新版本的VEE 9.2?是否有补丁?这是一个众所周知的问题 ?ThanksAndy 以上来自于谷歌翻译 以下为原文 Hello, I am running VEE 9.2 (build 9.2.135122 (Mar 22 2010) in WinXP SP3. I want to TURN OFF the SCPI code completion capability in the Direct IO transactions. I uncheck the SCPI XML Filename checkbox in the Advanced Instrument Properties as per the help. This seems to work once - as soon as I have a runtime error etc, the setting automatically reverts to having SCPI code completion enabled. Does anyone else have this problem? I really want to disable SCPI code completion - it even causes my typed transactions to become corrupted e.g. change the formatting after you have typed a syntax change in the transaction and the changes are lost !!!! Do I have the latest rev of VEE 9.2? Is there a patch? Is this a widely known problem? Thanks Andy |
1个回答
您好mk,以下是代码完成如何破坏您的一天并降低您的工作效率的示例1.打开启用了代码完成的直接IO对象并键入:“sens1:corr:coll”,lv.att(并设置格式
到Real64,已修复3)2。 现在复制事务并粘贴。 例如,假设我想查询我刚刚设置的内容:双击第二个事务,删除事务的lv.att部分并添加一个? 在引号内你有:“sens1:corr:coll?”现在将格式设置为默认格式 - 你的编辑是lot3。 如果您禁用代码完成,则不会发生这种情况。还有其他一些代码完成会破坏您的编辑,但对于初学者来说这是一个很好的演示.... Andy 以上来自于谷歌翻译 以下为原文 Hello mk, Here is an example of how Code Completion can spoil your day and reduce your productivity 1. Open up a direct IO object with Code Completion enabled and type: "sens1:corr:coll ", lv.att (and set the formatting to Real64, Fixed 3) 2. Now copy the transaction and paste. For example, let's say I want to query what I have just set: Double click on the 2nd transaction, delete the ,lv.att part of the transaction and add a ? inside the quotes so you have: "sens1:corr:coll?" And now set the format to Default format - your edits are lot 3. This does not happen if you disable code completion. There are other things that code completion screws up your edits on, but this is a nice demo for starters.... Andy |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 02:14 , Processed in 1.144336 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
532
