有没有人推荐使用Vivado的好处理器?
我目前有一个6核3.5GHz AMD设备,8GB内存。 我的设计不是很复杂(AXI总线,MIG,一些IP),但在Artix 100T上合成和实现大约需要25分钟。 谢谢 以上来自于谷歌翻译 以下为原文 Does anyone have a recommendation of a good processor to use with Vivado? I currently have a 6 core 3.5GHz AMD device with 8GB ram. I have a design that isn't very complex (AXI bus, MIG, some IP), yet it takes around 25 mins to synthesize and implement on an Artix 100T. Thanks |
4个回答
HI,
我认为对于8GB RAM机器来说,25分钟是常见的,如果你需要它更快,试试16GB 另请参阅下面UG的“系统内存建议”部分以及各种设备的链接。 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf http://www.xilinx.com/design-tools/vivado/memory.htm 希望这可以帮助 问候, Vanitha -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 HI, I think 25min is common for 8GB RAM machines, if you need it more faster try with 16GB Also please refer "System Memory Recommendations" section of below UG and links for various devices. http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf http://www.xilinx.com/design-tools/vivado/memory.htm Hope this helps Regards, Vanitha --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
你能检查一下是否启用了多处理?
根据UG904(Vivado Design Suite用户指南实施): “还有一个适用于所有任务的通用限制,基于操作系统。对于Windowssystems,限制为2;对于Linux系统,限制为8.可以使用名为general.maxThreads的参数更改限制。更改 limit:Vivado%set_param general.maxThreads -where新限制必须是1到8之间的整数。示例:在Windowssystem上:Vivado%get_param general.maxThreads2这意味着无论处理器数量多少,所有任务都限制为2个线程或 任务执行。如果系统至少有8个处理器,你可以将限制设置为8并允许每个任务使用最大线程数.Vivado%set_param general.maxThreads 8“ 以上来自于谷歌翻译 以下为原文 Can you check if multi processing is enabled? According to UG904 (Vivado Design Suite User Guide Implementation): "There is also a general limit that applies to all tasks and is based on the OS. For Windows systems, the limit is 2; for Linux systems the limit is 8. The limit can be changed using a parameter called general.maxThreads. To change the limit: Vivado% set_param general.maxThreads —where the new limit must be an integer from 1 to 8, inclusive. Example: On a Windows system: Vivado% get_param general.maxThreads 2 This means all tasks are limited to 2 threads regardless of number of processors or the task being executed. If the system has at least 8 processors, you can set the limit to 8 and allow each task to use the maximum number of threads. Vivado% set_param general.maxThreads 8" |
它确实使用2个线程用于P& R但不用于合成。
这需要花费最多的时间 以上来自于谷歌翻译 以下为原文 It does use 2 threads for P&R but not for synthesis. This is what takes the greatest amount of time |
似乎即使我只在verilog文件中更改了一件事,整个设计也会再次合成。
有没有办法让它重做已更改的模块? 例如,如果我有一个AXI总线,MIG,一些IP 1和2.如果我改变IP 1,它真的需要重做其他的吗? 以上来自于谷歌翻译 以下为原文 It seems that even if I only change one thing in a verilog file, the whole design gets synthesized again. Is there not a way for it to just redo the module that has changed? For instance if I have an AXI bus, MIG, some IP 1 and 2. If I change IP 1 does it really need to redo the others? |
只有小组成员才能发言,加入小组>>
2322 浏览 7 评论
2734 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2219 浏览 9 评论
3297 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2370 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
661浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
466浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
233浏览 1评论
672浏览 0评论
1868浏览 0评论
GMT+8, 2024-10-4 06:27 , Processed in 1.275389 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
