电子发烧友论坛|
阅读DS79000196F DS7000 00 195F -第19页,关于波特率设置(I2C1BRG)。注1:参考BRG再装入值计算的具体数据表。DSPIC33 EP512MC806数据表不提及I2C波特率。注2:如果没有计算……默认的BRG重载值应该被考虑……但是默认值是什么,我在哪里可以找到它?
以上来自于百度翻译 以下为原文 Reading Note 1: Refer to specific data sheet for BRG reload value calculation. dsPIC33EP512MC806 data sheet does not mention I2C Baud rate. Note 2: If no calculation...... default BRG reload value should be considered... But what is the default value, where can I find it? |
4个回答
你错误地引用了这张纸条。它说:“2:如果在数据表中没有计算,则应该考虑默认BrGrand值的计算。”“默认计算”是在该语句的正上方出现的。D在设备数据表中。
以上来自于百度翻译 以下为原文 You misquoted the note. It says: "2: If there is no calculation mentioned in the data sheet, then the default BRG reload value calculation should be considered." The "default calculation" is the one that appears immediately above that statement. It is saying to use that calculation if there isn't a more specific version listed in your device datasheet. |
单个寄存器通常在FRM中讨论,但是您可以在“所有重置”列下的数据表表4-22中找到默认设置。
以上来自于百度翻译 以下为原文 Individual registers are usually discussed in the FRM, but you can find the default settings in the datasheet Table 4-22 under the "All Resets" column. |
“权力的价值”是零,但这是无关的,它不是正确的句子指的是什么。
以上来自于百度翻译 以下为原文 The "power on value" is zero, but that's irrelevant, it's not what the correct sentence is referring to. |
HI,在I2C外围设备的硬件复位状态中没有可用的默认值。不同的PIC器件系列可能会从不同的源获取原始时钟信号,因此可能需要不同的计算。安全值将是振荡器频率除以I2C时钟频率:BRG= FoC/C.100000;对于更快的DSPICE…设备,注意该值不超过寄存器BRG字段中可容纳的最大值。如果产生的频率为预期的1/2,则调整设置。我认为对于DSPICHYSYEP设备和类似的70 MHz设备,正确的时钟信号可以是外围设备。时钟:FP= FOSC/2给出:BRG=FP/(2×Fi2C)MysIL
以上来自于百度翻译 以下为原文 Hi, There is no useable default value in hardware reset state for I2C peripheral. Different families of PIC devices may take the raw clock signal from somewhat different sources, so may need different calculations. A safe value would be oscillator frequency divided by I2C clock frequency: BRG = fOSC / 100000; For the faster dsPICE... devices, take care that the value do Not exceed the maximum value that may be accomodated in BRG field of the register. If the resulting frequency is 1/2 of what was expected, adjust the setting. I think that for dsPIC___EP devices and similar 70 MHz devices, the correct clock signal may be Peripheral clock: FP = FOSC/2 giving: BRG = Fp / ( 2* FI2C) Mysil |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 04:53 , Processed in 1.132697 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
550
