电子发烧友论坛|
亲爱的All,我想远程DSOX90000A范围用触发信号自动采集波形数据,软件将安装在示波器(Windows 7系统)上,那么如何在VEE中设置示波器地址?
非常感谢Alex 以上来自于谷歌翻译 以下为原文 Dear All, I want to remote the DSOX90000A scope to acquire waveform data automatic with trigger signal, and the software will be install on the scope(windows 7 system), so how to set the scope address in the VEE? thanks a lot Alex |
1个回答
您的问题是“如何设置示波器地址?”。
如果是这样,那么这是你通常不会对VEE做的事情。 相反,请参阅仪器的用户手册,了解如何设置远程接口。 对于现代产品有如此多的选项,您可能首先需要设置要用于控制它的接口(GPIB,串行或任何您想要使用的接口),然后根据需要设置地址。 如果您仍然遇到问题,请告诉我们您要使用的通信接口,也许有人可以指导您进行设置。 以上来自于谷歌翻译 以下为原文 Is your question "how do I set the oscilloscope address?".? If so, then this is something you would not [normally] do with VEE. Instead, consult the instrument's user manual on how to set up the remote interface. With so many options on modern products, you'll probably first need to set which interface you want to use to control it ( GPIB, serial or whatever you intend using ) and then, if appropriate, set the address. If you still have problems, let us know which communications interface you want to use and maybe someone will be able to guide you to the setting. |
只有小组成员才能发言,加入小组>>
290 浏览 0 评论
1871 浏览 0 评论
2757 浏览 1 评论
2658 浏览 1 评论
2478 浏览 5 评论
1871浏览 0评论
434浏览 0评论
290浏览 0评论
/9
GMT+8, 2025-12-14 15:14 , Processed in 0.705735 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2161
