电子发烧友论坛|
Hithe受试者说了这一切,有人知道,在编辑器中,有一种方法来选择文本和改变案件的上限或下限,我不担心资本化只是一个直上或下。MPLAB和其他编辑一样。在我看来,我似乎看不到路。
以上来自于百度翻译 以下为原文 Hi The subject says it all, does any one know, in the editor, is there a way to select text and change the case to upper or lower, I'm not bothered about capitalisation just a straight upper or lower. MPLAB had this, as does virtually every other editor. I can't seem to see way in mplabx Regards Rob |
2个回答
选择要更改的文本,然后尝试CRTL U跟随BUU转换为大写ORL以转换为小写。这至少在MPLAB V3.61(Windows平台)中是可行的。
以上来自于百度翻译 以下为原文 Select the text you want to change and try CTRL-U followed by u to convert to upper case or l to convert to lower case. This works, at least in MPLAB X v3.61 (Windows platform). |
我还发现这些非常有用。提示:你可以找到许多快捷键(甚至设置它们),如果你去:菜单“工具”& GT;条目“选项”&类别“KEYMAP”,你可以进入你正在寻找的“搜索”字段。然而,往往很难猜出他们是如何命名这个动作的。你可能也会发现那些不适合你期望的事情,但我在那里发现了一些不错的东西。移动线(s)向上/向下,“重复行(s)向上/向下”,“切换矩形选择”,“删除尾随空间”或“查找用法”,仅举几个例子。
以上来自于百度翻译 以下为原文 I also found these ones quite useful. Hint: You can find out many shortcut keys (or even set them) if you go to: menu "Tools" > entry "Options" > category "Keymap" You can then enter the feature you are looking for into the "Search:" field. However, often it is difficult to guess how they have named the action. And you might also find things which don't do what you expect them to do. But I found some nice ones there. "Move Line(s) Up/Down", "Duplicate Line(s) Up/Down", "Toggle Rectangular Selection", "Remove Trailing Spaces" or "Find Usages", just to name a few. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5795 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1126浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-3 07:01 , Processed in 0.682437 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3013
