当配置带有DDR3外部存储器接口和ICache的微网格时,ICACHE的高地址和低地址对应于ddr3的地址范围。
这很奇怪,因为ddr3是128 MB而icache是8Kb。 是否必须更改微填充Icache的地址区域,因为如果没有,则整个DDR3使用XCL接口而不是缓存连接到微网格。 关于这个的任何想法? 以上来自于谷歌翻译 以下为原文 When configuring thwe microblaze with a DDR3 external memory interface and the ICache enbaled, the high and low addresses of the ICACHE correspond to the address range of the ddr3. This is weird as the ddr3 is 128 MB and the icache is 8Kb. Does one have to change the address region of the microblaze Icache because if not, then the entire DDR3 is connected to the microblaze using the XCL interface rather than the cache. Any ideas regarding this? |
4个回答
处理器缓存通常不是直接映射的,这是您所描述的。
它们具有某种所谓的“缓存关联性”,它基本上可以将缓存划分为小部分,并且基于访问哪些地址,每个部分可以缓存较大存储器的某个区域(在这种情况下为dram)。 当然,关联性有其自身的成本(主要是硬件和缓存延迟),因此不会使缓存完全关联(即每个字都可以指向不同的dram地址)。 在MB中,可以在生成期间设置缓存关联性。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 Processor caches are usually not direct mapped which is what you are describing. They have a certain what's termed "cache associativity" which basically can divide the cache into small sections and based on which addresses are accessed each section can cache a certain region of the larger memory (dram in this case). Of course associativity has its own cost (mainly hardware and cache latency) so one doesn't make a cache fully associative (ie every word can point to a different dram address). In MB, cache associativity can be set during generation.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
那么,数据缓存基地址和高地址只是表明什么是可缓存地址?
在配置微纤维时,可以选择在哪里更改缓存的关联性? 我没看到。 而且默认情况下,关联性和集合方面的缓存参数是什么? 以上来自于谷歌翻译 以下为原文 So, the data cache base address and high address just indicate what is the cacheable address? And where is the option to change the associativity of the cache when configuring the microblaze? I do not see it. And also by default what are the cache parameters in terms of associativity and sets? |
你好
有关缓存组织的信息,请参见http://www.xilinx.com/support/documentation/sw_manuals/mb_ref_guide.pdf的第63页。 --HS -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 Hi The cache organization is mentioned in page 63 of http://www.xilinx.com/support/documentation/sw_manuals/mb_ref_guide.pdf --HS ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
是基地址和高地址表示可缓存区域。
关于关联性:事实证明MB缓存是单向的,即直接映射,因此它们没有关联性配置。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 Yes base address and high address indicate the cacheable region. About associativity: it turns out the MB caches are 1-way ie direct mapped, so there is no associativity configuration for them.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
只有小组成员才能发言,加入小组>>
2322 浏览 7 评论
2734 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2369 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
655浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
463浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
222浏览 1评论
669浏览 0评论
1861浏览 0评论
GMT+8, 2024-10-1 07:58 , Processed in 1.152444 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
