弄了块 STM32L152 discovery的板子 现在串口发送一直不成功,请大家帮我看看
int main(void) { USART_InitTypeDef USART_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_HSICmd(ENABLE); /*!< Wait till HSI is ready */ while (RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); /* Set HSI as sys clock*/ RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); /* Enable GPIO clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE); /* Enable UART clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); /* Connect PXx to USARTx_Tx */ GPIO_PinAFConfig(GPIOA, GPIO_Pin_9,GPIO_AF_USART1); /* Connect PXx to USARTx_Rx */ GPIO_PinAFConfig(GPIOA, GPIO_Pin_10,GPIO_AF_USART1); /* Configure USART Tx as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Configure USART Rx as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_Init(GPIOA, &GPIO_InitStructure); USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; /* USART configuration */ USART_Init(USART1, &USART_InitStructure); /* Enable USART */ USART_Cmd(USART1, ENABLE); while(1) { USART_SendData(USART1, 'A'); /* Loop until transmit data register is empty */ while (USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET) {} } } |
9个回答
详见数据手册
楼主测试一下IO口有波形输出没,乱码也收不到吗?
应该是RCC配置的问题,下面这段如果在DEBUG单步一下一下的走完,后面的直接运行就没问题。如果中间没停直接走,就不行。。有谁用过HSI的么
RCC_HSICmd(ENABLE); while (RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div1); RCC_PCLK2Config(RCC_HCLK_Div2); //FLASH_SetLatency(FLASH_Latency_1); // FLASH_PrefetchBufferCmd(ENABLE); RCC_PLLConfig(RCC_PLLSource_HSI, RCC_PLLMul_3, RCC_PLLDiv_3); RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) != SET); RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK ); while((RCC_GetSYSCLKSource()) != 0x0c); RCC_GetClocksFreq(&RCC_ClockFreq); |
RCC_GetClocksFreq(&RCC_Clocks);
//GPIO端口配置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; /* Enable GPIO clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); /* Enable USART1 clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); /* Configure USART1 EN as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //输出模式 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Configure USART Tx as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Connect PXx to USARTx_Tx */ GPIO_PinAFConfig(GPIOA, GPIO_PinSource9,GPIO_AF_USART1); /* Connect PXx to USARTx_Rx */ GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_USART1); /* USART configuration */ USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1,&USART_InitStructure); /* Enable the USARTx Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 6; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); USART_ITConfig(USART1, USART_IT_RXNE,ENABLE); |
这个问题解决了,搞不清我用HSI 做时钟源PLL跑不到32MHZ ,只有在16MHZ才行 这是调试可用的USART代码
#include "BSP_USART.h" #include "stm32l1xx.h" #include /******************************************************************************* * 函数名 : GPIO_Configuration * 函数描述 : 设置各GPIO端口功能 * 输入参数 : 无 * 输出结果 : 无 * 返回值 : 无 *******************************************************************************/ static void USART_GPIO_Configuration(void) { /* 定义GPIO初始化结构体 GPIO_InitStructure */ GPIO_InitTypeDef GPIO_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA , ENABLE); /* Enable GPIO clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 , ENABLE); /* 设置USART1的Tx脚(PA.9)为第二功能推挽输出功能 */ GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; // GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_Init(GPIOA , &GPIO_InitStructure); /* 设置USART1的Rx脚(PA.10)为浮空输入脚 */ GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; GPIO_Init(GPIOA , &GPIO_InitStructure); //RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA , ENABLE); } /******************************************************************************* * 函数名 : USART_Configuration * 函数描述 : 设置USART1 * 输入参数 : None * 输出结果 : None * 返回值 : None *******************************************************************************/ static void USART_Configuration(void) { /* 定义USART初始化结构体 USART_InitStructure */ USART_InitTypeDef USART_InitStructure; /* 定义USART初始化结构体 USART_ClockInitStructure */ USART_ClockInitTypeDef USART_ClockInitStructure; /* 波特率为115200bps; * 8位数据长度; * 1个停止位,无校验; * 禁用硬件流控制; * 禁止USART时钟; * 时钟极性低; * 在第2个边沿捕获数据 * 最后一位数据的时钟脉冲不从 SCLK 输出; */ // USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; // USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; // USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; // USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; // USART_ClockInit(USART1 , &USART_ClockInitStructure); USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No ; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1 , &USART_InitStructure); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_ITConfig(USART1, USART_IT_TXE, DISABLE); USART_ClearFlag(USART1,USART_FLAG_TC); /* 使能USART1 */ USART_Cmd(USART1 , ENABLE); } /******************************************************************************* * 函数名 : USART_Init * 函数描述 : USART初始化 * 输入参数 : None * 输出结果 : None * 返回值 : None *******************************************************************************/ void BSP_USART_Init(void) { RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA , ENABLE); /* Enable GPIO clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 , ENABLE); USART_GPIO_Configuration(); USART_Configuration(); } void USART1_IRQHandler(void) { if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET) //?????????? { USART_ClearITPendingBit(USART1, USART_IT_TXE); USART_ITConfig(USART1, USART_IT_TXE, DISABLE); } if(USART_GetITStatus(USART1, USART_IT_RXNE)==SET) { USART_ClearITPendingBit(USART1,USART_IT_RXNE); USART_SendData(USART1,USART_ReceiveData(USART1 )); // USART2_Buffer_Rx[Usart_Buffer_Size++] = USART_ReceiveData(USART1); // if(Usart_Buffer_Size == 7) // { // Usart_Buffer_Size = 0; // Usart_Recieve_flag = 1; // } } } |
上次遗漏了HSI时钟设置,可以跑到32MHz。
修改system_stm32l1xx.c文件 * @brief Configures the System clock frequency, AHB/APBx prescalers and Flash * settings. * @note This function should be called only once the RCC clock configuration * is reset to the default reset state (done in SystemInit() function). * @param None * @retval None */ static void SetSysClock(void) { __IO uint32_t StartUpCounter = 0, HSIStatus = 0; /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/ /* Enable HSI 内部时钟使能*/ RCC->CR |= ((uint32_t)RCC_CR_HSION); //RCC_CR_HSEON替换成RCC_CR_HSION /* Wait till HSI is ready and if Time out is reached exit */ /* 等待外部时钟就绪,超时推出 */ do { HSIStatus = RCC->CR & RCC_CR_HSIRDY; //RCC_CR_HSEON替换成RCC_CR_HSION,HSIStatus替换成HSEStatus StartUpCounter++; } while((HSIStatus == 0) && (StartUpCounter != HSI_STARTUP_TIMEOUT));//HSIStatus替换成HSEStatus if ((RCC->CR & RCC_CR_HSIRDY) != RESET) //RCC_CR_HSEON替换成RCC_CR_HSION { HSIStatus = (uint32_t)0x01; //超时置1 //HSEStatus替换成HSIStatus } else { HSIStatus = (uint32_t)0x00; //HSEStatus替换成HSIStatus } if (HSIStatus == (uint32_t)0x01) //HSEStatus替换成HSIStatus { /* Enable 64-bit access */ FLASH->ACR |= FLASH_ACR_ACC64; /* Enable Prefetch Buffer */ FLASH->ACR |= FLASH_ACR_PRFTEN; /* Flash 1 wait state */ FLASH->ACR |= FLASH_ACR_LATENCY; /* Power enable */ RCC->APB1ENR |= RCC_APB1ENR_PWREN; /* Select the Voltage Range 1 (1.8 V) */ PWR->CR = PWR_CR_VOS_0; /* Wait Until the Voltage Regulator is ready */ while((PWR->CSR & PWR_CSR_VOSF) != RESET) { } /* HCLK = SYSCLK /1*/ RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1; /* PCLK2 = HCLK /1*/ RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1; /* PCLK1 = HCLK /1*/ RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1; /* PLL configuration */ RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLMUL | RCC_CFGR_PLLDIV)); RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI | RCC_CFGR_PLLMUL4 | RCC_CFGR_PLLDIV2); //RCC_CFGR_PLLSRC_HSE替换成RCC_CFGR_PLLSRC_HSI /* Enable PLL */ RCC->CR |= RCC_CR_PLLON; /* Wait till PLL is ready */ while((RCC->CR & RCC_CR_PLLRDY) == 0) { } /* Select PLL as system clock source */ RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW)); RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL; /* Wait till PLL is used as system clock source */ while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL) { } } else { /* If HSI fails to start-up, the application will have wrong clock configuration. User can add here some code to deal with this error */ } 然后 int main(void) { RCC_GetClocksFreq(&RCC_Clocks); //GPIO端口配置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; /* Enable GPIO clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); /* Enable USART1 clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); /* Configure USART1 EN as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //输出模式 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Configure USART Tx as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Connect PXx to USARTx_Tx */ GPIO_PinAFConfig(GPIOA, GPIO_PinSource9,GPIO_AF_USART1); /* Connect PXx to USARTx_Rx */ GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_USART1); /* USART configuration */ USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1,&USART_InitStructure); /* Enable the USARTx Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 6; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); USART_ITConfig(USART1, USART_IT_RXNE,ENABLE); while(1) { //... } } |
单步没问题而全速不行的,我调试stm32f091的串口时碰到过一次,后来发现是因为全速时有个标志没有判断,导致运行到下一句时上一个字节还没有发送完成,而单步调试时因为每一步时间都足够所以没有问题,供参考。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2776 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2379 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2255 浏览 0 评论
2367 浏览 1 评论
1625 浏览 1 评论
/9
GMT+8, 2025-12-1 18:40 , Processed in 0.963597 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1783
