电子发烧友论坛|
嗨,
我们正在使用SPC560B64控制器并且想要启动STM_0,无法启动STM计数器。请提供STM计时器启动的示例代码。 问候, Bhagyashri 以上来自于谷歌翻译 以下为原文 Hi, We are using SPC560B64 controller and want to start STM_0, unable to start STM counter. Please provide us the sample code for STM timer start. Regards, Bhagyashri |
2个回答
你好,
当前版本的SPC5Studio支持用于RLA架构的STM驱动程序。驱动程序为所有支持的平台(包括spc560b)提供了自己的测试应用程序。只需使用向导导入它,生成,您将获得所需的代码。 STM计数器启动代码位于stm_lld_enable函数中 void stm_lld_enable(STMDriver * stmd){ uint8_t i; / *设置预分频器* / stmd-&gt; stm_tagp-&gt; CR.R =(stmd-&gt; prescaler-1U)&lt;&lt; 8; / *设置比较寄存器和启用通道* / for(i = 0; i&lt; stmd-&gt; noofchannels; i ++){ if(stmd-&gt; stm_ch_config .enabled == TRUE){ / *设置比较寄存器* / stmd-&gt; stm_tagp-&gt; CH .CMP.B.CMP = stmd-&gt; stm_ch_config .counter; / *清除中断标志* / stmd-&gt; stm_tagp-&gt; CH .CIR.B.CIF = STM_CCR_CIF_CLEAR; / *启用频道* / stmd-&gt; stm_tagp-&gt; CH .CCR.B.CEN = STM_CIR_CEN_ENABLE; } } / *重置计数器* / stmd-&gt; stm_tagp-&gt; CNT.R = 0x00000000U; / *启用STM * / stmd-&gt; stm_tagp-&gt; CR.B.TEN = STM_CR_TEN_ENABLE; } 问候 以上来自于谷歌翻译 以下为原文 Hello, current version of SPC5Studio supports STM driver for RLA architecture. Driver comes with his own test application for all supported platform includind spc560b. Simply import it using the wizard, generate and you will get the code you need. the STM counter start code is located in stm_lld_enable function void stm_lld_enable (STMDriver *stmd){ uint8_t i; /* set the prescaler */ stmd->stm_tagp->CR.R = (stmd->prescaler-1U) << 8 ; /* set compare register and enable channels */ for (i=0; i if (stmd->stm_ch_config.enabled == TRUE){ /* set compare register */ stmd->stm_tagp->CH.CMP.B.CMP = stmd->stm_ch_config.counter; /* clear interrupt flag */ stmd->stm_tagp->CH.CIR.B.CIF = STM_CCR_CIF_CLEAR; /* enable channel */ stmd->stm_tagp->CH.CCR.B.CEN = STM_CIR_CEN_ENABLE; } } /* reset counter */ stmd->stm_tagp->CNT.R = 0x00000000U; /*enable STM */ stmd->stm_tagp->CR.B.TEN = STM_CR_TEN_ENABLE; } Regards |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 02:24 , Processed in 0.661811 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
567
