用51单片机控制ST7920的液晶,有些字显示不出来,请各位老大帮忙看看程序哪有问题 #include "reg52.h" #include "intrins.h" ***it io_LCD12864_RS = P1^0 ; ***it io_LCD12864_RW = P1^1 ; ***it io_LCD12864_EN = P1^2 ; #define io_LCD12864_DATAPORT P0 #define SET_DATA io_LCD12864_RS = 1 ; #define SET_INC io_LCD12864_RS = 0 ; #define SET_READ io_LCD12864_RW = 1 ; #define SET_WRITE io_LCD12864_RW = 0 ; #define SET_EN io_LCD12864_EN = 1 ; #define CLR_EN io_LCD12864_EN = 0 ; void v_Lcd12864CheckBusy_f( void ) //忙检测函数 { unsigned int ntimeOut = 0 ; SET_INC SET_READ CLR_EN SET_EN while( ( io_LCD12864_DATAPORT & 0x80 ) && ( ++nTimeOut != 0 ) ) ; CLR_EN SET_INC SET_READ } void v_Lcd12864SendCmd_f( unsigned char byCmd ) //发送命令 { v_Lcd12864CheckBusy_f() ; SET_INC SET_WRITE CLR_EN io_LCD12864_DATAPORT = byCmd ; _nop_(); _nop_(); SET_EN _nop_(); _nop_(); CLR_EN SET_READ SET_INC } void v_Lcd12864SendData_f( unsigned char byData ) //发送数据 { v_Lcd12864CheckBusy_f() ; SET_DATA SET_WRITE CLR_EN io_LCD12864_DATAPORT = byData ; _nop_(); _nop_(); SET_EN _nop_(); _nop_(); CLR_EN SET_READ SET_INC } unsigned char LcdRdata(void)//读数据 { unsigned char LcdData; io_LCD12864_DATAPORT=0xff; SET_READ SET_DATA SET_EN _nop_(); _nop_(); LcdData = io_LCD12864_DATAPORT; CLR_EN return (LcdData); } void v_DelayMs_f( unsigned int nDelay ) //延时 { unsigned int i ; for( ; nDelay > 0 ; nDelay-- ) { for( i = 125 ; i > 0 ; i-- ) ; } } void v_Lcd12864Init_f( void ) //初始化 { v_Lcd12864SendCmd_f( 0x30 ) ; //基本指令集 v_DelayMs_f( 50 ) ; v_Lcd12864SendCmd_f( 0x01 ) ; //清屏 v_DelayMs_f( 50 ) ; v_Lcd12864SendCmd_f( 0x06 ) ; //光标右移 v_DelayMs_f( 50 ) ; v_Lcd12864SendCmd_f( 0x0c ) ; //开显示 } void v_Lcd12864SetAddress_f( unsigned char x, y ) //地址转换 { unsigned char byAddress ; switch( y ) { case 0 : byAddress = 0x80 + x ; break; case 1 : byAddress = 0x90 + x ; break ; case 2 : byAddress = 0x88 + x ; break ; case 3 : byAddress = 0x98 + x ; break ; default : break ; } v_Lcd12864SendCmd_f( byAddress ) ; } void v_Lcd12864PutString_f( unsigned char x, unsigned char y, unsigned char *pData ) //任意位置显示内容 { v_Lcd12864SetAddress_f( x, y ) ; while( *pData != ' |
