电子发烧友论坛|
嗨我即将购买旧的8590 SA,因为这个问题很便宜。
本机可以在屏幕上显示校准信号的频谱和所有其他字符,但屏幕上满是雪,垂直线很少。 看起来CRT以错误的方式绘制网格。 这是设置问题还是内部有问题。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi I am about to purchase a old 8590 SA, which is quite cheap because of this issue. This unit can display spectrum of calibration signal and all the other characters on screen, but the screen is full of snow and there are few vertical lines. It looks like the CRT draws grids the wrong way. Is it the setting problem or there are something wrong inside. Thanks. |
3个回答
嗨 - 我认为这个旧的,不支持的工具被打破了。
这听起来像CRT,甚至可能是处理器板导致问题。 我相信安捷伦不再提供所有8590部件,因此我们无法对旧硬件进行维修。 对不起 - 但希望这有帮助 - 以上来自于谷歌翻译 以下为原文 Hi - I think this old, out-of-support instrument is broken. It sounds like the CRT, or even perhaps the processor board is causing the issue. I believe all 8590 parts are no longer supplied by Agilent, so repairs on old hardware simply cannot be performed by us. Sorry - but hope this helped - |
嗨,它不一定是CRT管。
我的猜测是视频驱动电路中的同步问题。 如果你让它运行半小时,那会有什么区别吗? 如果是这样,它可能是一个干燥的电解电容器。 其中一些乐器具有视频输出。 使用外部视频监控器,您可以检查输出。 (我有一次CRT故障并且输出视频运行良好。)问候Jens 以上来自于谷歌翻译 以下为原文 Hi, It doesn't have to be the CRT-tube. My guess would be a sync problem in the video driver circuits. If you let it run for let say half an hour, would there be any difference? If so it might be an electrolytic capacitor that has dried out. Some of these instruments have an output for video. With an external videomonitor you can check the output. (I had one once with a CRT fault and the output video worked well.) Regards Jens |
伙计们,你可能会尝试的一件事是检查水平位置DAC是否没有被强制到一个极端或另一个极端,因为这有时会导致水平同步丢失,并且光栅会过度地“模糊”。
按:CAL,更多(6),CRT HORIZ POSITION(4),然后旋转RPG或在键盘上输入低数字(范围约1到50)。 [注意:括号中的数字表示屏幕软键,顶部为1,最低为6]。 还可以尝试:配置,更多(6),默认配置(4)配置,更多(6),更多(6),默认同步(3)不要忘记显示器本身也有水平保持调整,有 封面上的访问权限,但不会被标记。 如果我记得的话,旧的8590A服务手册中有一个监视器服务附录。 如果你还有问题,我可以得到相关的图像。 我希望这很有用。 干杯, 以上来自于谷歌翻译 以下为原文 Folks, One thing you might try is to check the Horizontal Position DAC is not railed to one extreme or another, as this can sometimes cause the horizontal synchronisation to be lost, and the raster become 'smeared' sideways excessively. Press: CAL, More (6), CRT HORIZ POSITION (4), then rotate the RPG or type in low number (range about 1 to 50) on the keypad. [Note: number in brackets indicates screen softkeys, with 1 at the top, and 6 the lowest]. Also try: CONFIG, More (6), DEFAULT CONFIG (4) CONFIG, More(6), More (6), DEFAULT SYNCH (3) Don't forget there is also a Horizontal Hold adjustment on the monitor itself, there is an access hol;e in the cover, but it will not be labelled. There is a monitor servicing appendix in the old 8590A service manual if I remember. If you still have trouble I could get the relevant image. I hope this is useful. Cheers, |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 19:25 , Processed in 0.802700 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1484
