电子发烧友论坛|
您好,目前我正在进行关于模拟器设计主题的最后一年项目。
它需要构建一个软件,将现有的特定系统命令转换为可以被新仪器识别的新命令。 例如,我们正在使用为8657 Sig Generator设计的系统,现在我们想切换到EE4422,而不需要更改整个软件系统,我们想用旧软件驱动新仪器。 我知道有一个Agilnet仿真器可以执行相同的功能,但我需要自己创建一个软件。 我现在想到的是,我将旧系统命令转换为由我设计的新系统命令,然后我将对新系统命令执行相同操作,因此我可以匹配相应的命令并在它们之间构建桥接。 我决定用Visual Basic编写软件,但我不太确定我的方法的可行性。 因此,我真诚地寻求一些建议。 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, Currently I am doing my Final Year Project on a topic of emulator design. It requires to build a software which translates the existing specific system commands into new ones that can be recognized by new instruments. For example, we are using the system designed for 8657 Sig Generator, and now we want to switch to EE4422, without changing the whole software system, we would like to drive the new instrument with the old software. I know that there is one Agilnet emulator that does the same function, yet I need to create a software by myself. What I have in mind now is that I will translate the old system commands into a new one designed by me then I will do the same thing to the new system commands, so I may match the cooresponding commands and build the bridge between them. I have decided to write the software with Visual Basic, yet I am not so sure about the feasibility of my method. Therefore, I sincerely look for some advice. Thank you. |
4个回答
嗨,就目前而言,您可能想要做的就是熟悉您使用的硬件。
尝试了解他们使用的命令语言。 我认为,制作模拟器的愚蠢方法是逐个命令地翻译。 但如果你想获得更好的成绩,你可能不想为你的FYP做那个,所以试着想出一个更聪明的方法:p LOL,希望它可能有所帮助! 以上来自于谷歌翻译 以下为原文 Hi, for now, wht u may want to do is to get really familiar with the hardwares u r using. try to understand the command language they r using. the stupid way of making an emulator, my opinion, is to translate command by command. but u may not want to do that for ur FYP if u want to get a better grade so try to come up with a smarter way :p LOL, hope it may help! |
您好,感谢您的好意见。 最后我在每日检查后得到了答复。 我目前正在研究硬件和gpib控制语言。 我在理解它们时面临一些困难。 我会将所有问题列表并与您协商,也许吧? 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, Thank you for your kind advice. Finally I got response after daily check. I am currently studying the hardware and gpib control language. I am facing some difficulties understanding them. I will tabulate all the questions and consult with you, maybe? Thank you. |
嗨,不要问我......我不知道你的硬件......你可以咨询其他人,专家,也许是你的教授? 我不知道。 但就视觉基础而言,我可能会回答一些问题,毕竟,我已经做了一段时间了。 尽管如此! 以上来自于谷歌翻译 以下为原文 Hi, dont ask me... I dont know ur hardwares... u may consult with some one else, experts, maybe ur prof? i dont know. but in terms of visual basic, i may answer some, after all, i hv been working on that for some time alr. all the best though! |
60user40 发表于 2019-2-26 09:10 您好,感谢您的回复。 以上来自于谷歌翻译 以下为原文 Hello, Thank you for your kind responce. |
只有小组成员才能发言,加入小组>>
1854 浏览 0 评论
2749 浏览 1 评论
2651 浏览 1 评论
2471 浏览 5 评论
3475 浏览 3 评论
1854浏览 0评论
427浏览 0评论
/9
GMT+8, 2025-12-8 11:26 , Processed in 0.963714 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2223
