电子发烧友论坛|
嗨,debugasm - 我最近有一个客户有选择1EL,他们没有得到任何东西,我没有和Q没有。
检查它的好方法是将SINE_TEST_WFM波形加载到Dual Arb并播放它。 您应该在所有四个端口上看到幅度为800 mVpp的正弦波,I,Q,I not,而Q则不是。 没有在I not和Q上获得正确输出的客户不需要将其固件升级到1.86。 如果您有旧固件,我建议您升级,然后查看输出。 问候 - 以上来自于谷歌翻译 以下为原文 Hi debugasm - I recently had a customer who had option 1EL and they weren’t getting anything out of the I not and Q not. A good way to check this it to load up the SINE_TEST_WFM waveform into the Dual Arb and play it. You should see a sine wave with an amplitude of 800 mVpp on all four ports, I, Q, I not, and Q not. The customer that wasn’t getting the correct output on the I not and Q not needed to upgrade their firmware to 1.86. If you have old firmware, I suggest you upgrade and then look at the outputs. Regards - |
醉狼工作室 发表于 2019-2-25 20:33 嗨tabbott,>我最近有一个客户谁有选项1EL,他们没有得到任何东西我不是和Q没有。 我的发电机安装了最新的固件,还有许可证1EL。 >检查它的好方法是将SINE_TEST_WFM波形加载到Dual Arb并播放它。 我按照你的说法做了,信号Ip和Qp是完美的,但信号In和Qn低了1/10,好像有人减弱了它。 我会再进行一些测试,发电机不在保修范围内,也不能正常工作,但不是我的错。 非常感谢。 加布里埃莱 以上来自于谷歌翻译 以下为原文 Hi tabbott, > I recently had a customer who had option 1EL and they weren’t getting anything out of the I not and Q not. My generator has the latest firmware installed and also the license 1EL. > A good way to check this it to load up the SINE_TEST_WFM waveform into the Dual Arb and play it. I did as you said, the signals Ip and Qp are perfect but the signals In and Qn are 1/10 lower as if someone attenuate this. I'll do a few more tests, the generator is out of warranty and not working, but no fault of mine. Thanks very much. Gabriele |
醉狼工作室 发表于 2019-2-25 20:33 嗨tabbott,>我最近有一个客户谁有选项1EL,他们没有得到任何东西我不是和Q没有。 我的发电机安装了最新的固件,还有许可证1EL。 >检查它的好方法是将SINE_TEST_WFM波形加载到Dual Arb并播放它。 我按照你的说法做了,信号Ip和Qp是完美的,但信号In和Qn低了1/10,好像有人减弱了它。 我会再进行一些测试,发电机不在保修范围内,也不能正常工作,但不是我的错。 非常感谢。 debugasm 以上来自于谷歌翻译 以下为原文 Hi tabbott, > I recently had a customer who had option 1EL and they weren’t getting anything out of the I not and Q not. My generator has the latest firmware installed and also the license 1EL. > A good way to check this it to load up the SINE_TEST_WFM waveform into the Dual Arb and play it. I did as you said, the signals Ip and Qp are perfect but the signals In and Qn are 1/10 lower as if someone attenuate this. I'll do a few more tests, the generator is out of warranty and not working, but no fault of mine. Thanks very much. debugasm |
只有小组成员才能发言,加入小组>>
1854 浏览 0 评论
2749 浏览 1 评论
2651 浏览 1 评论
2471 浏览 5 评论
3475 浏览 3 评论
1855浏览 0评论
427浏览 0评论
/9
GMT+8, 2025-12-9 06:31 , Processed in 0.897394 second(s), Total 82, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2398
