大家好,有人可以向我解释一下ISE和Mircoblaze是如何结合在一起的吗?
目前我已经在ISE中用VHDL编写了一个程序,我希望在我的设计中添加一个mircoblaze。 我该怎么做以及micrlaze和我的VHDL代码如何集成和协同工作? 以上来自于谷歌翻译 以下为原文 Hello all, could someone please explain to me how ISE and Mircoblaze combine together? Currently i have written a program in VHDL in ISE, i wish to add in a mircoblaze to my design. How do i do it and how can the microblaze and my VHDL code integrate and work together? |
2个回答
G,
这就是EDK / SDK工具的用途...... 可以使用ISE的“逻辑版”,但是在不使用将处理集成到逻辑中时开发的工具的情况下处理MicroBlaze(tm)IP核更加困难(基本上,我们支持使用MicroBlaze EDK / SDK工具)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 g, That is what the EDK/SDK tools are for..... The "logic edition" of ISE may be used, but it is more difficult to deal with the MicroBlaze(tm) IP core without using the tools that were developed when you integrate processing into the logic (basically, we support use of MicroBlaze using the EDK/SDK tools). Austin Lesea Principal Engineer Xilinx San Jose |
你问了一个非常开放的问题,答案取决于你想要做什么。
在没有EDK的Core发生器中有一个“MicroBlaze微控制器”。 你会 仍需要用于C编程的SDK,而不是ISE的完整嵌入式版本。 这有 它的局限性在于它只能从内部Block RAM运行,并且具有一组有限的外设。 但是,如果这足够好,它可以像您的PicoBlaze一样轻松地与您的ISE项目集成。 如果您需要高级外围设备,或者从外部存储器运行代码,那么您需要 EDK。 您仍然可以使用ISE启动项目并从EDK项目添加MicroBlaze 作为ISE的一个模块。 如果您有嵌入式版本,可以从ISE Navigator GUI中获取 转到Project - > New Source ...并选择“Embedded Processor”以启动该过程。 - Gabor - Gabor 以上来自于谷歌翻译 以下为原文 You asked a very open-ended question and the answer depends on what you're trying to do. There is a "MicroBlaze Microcontroller" available in Core generator without the EDK. You would still need the SDK for C programming, but not the full Embedded edition of ISE. This has limitations in that it only runs from internal block RAM and has a limited set of peripherals. However if that's good enough, it can be as easy to integrate with your ISE project as a PicoBlaze. If you need advanced peripherals, or to run code from external memory, then you'd need the EDK. You can still start your project with ISE and add the MicroBlaze from the EDK project as a module in ISE. If you have the Embedded edition, from the ISE Navigator GUI you can go to Project --> New Source... and select "Embedded Processor" to start the process. -- Gabor -- Gabor |
只有小组成员才能发言,加入小组>>
2320 浏览 7 评论
2729 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2366 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
652浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
460浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
220浏览 1评论
667浏览 0评论
1859浏览 0评论
GMT+8, 2024-9-28 13:35 , Processed in 1.194392 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
