电子发烧友论坛|
我刚刚开始调试一个用创建者2做的项目
器件PSOC5 CY8C55×8AXI-060*'成功编程于12/07/2011 19:11:44。警告:不能设置断点:'C:CyPress 另一个测试区域TestPultTestPWM。CysN\Meal.C:27’。遇到错误(在目标中没有硬件断点支持)。错误:dg.M90015:调试器在运行期间意外退出。遇到错误(远程通信错误:无错误)。 快乐调试? 鲍勃 以上来自于百度翻译 以下为原文 I just started debugging a project made with creator 2.0 ang got the following errormessage Device 'PSoC5 CY8C55*8AXI-060*' was successfully programmed at 12/07/2011 19:11:44. Warning: Cannot set breakpoint: 'C:CypressAnother TestareaTestPWMTestPWM.cydsnmain.c:27'. Encountered error (No hardware breakpoint support in the target.). Error: dbg.M0015: Debugger exited unexpectedly during run. Encountered error (Remote communication error: No error.) Happy debugging? Bob |
26个回答
你好,
谢谢你帮我的忙。我刚刚复习过: 使用CY8C5688 AX*- 60 ES1(这就是MixPro 3所说的) 我在创建2的修订文档中红了:ES1不再支持。 可能是错误。如果你能用ES1获得PSOC5处理器模块,你可以试试。 对于模块当前没有ESE交换程序吗?(我住在德国,怎么办?)??) 问候,鲍伯 以上来自于百度翻译 以下为原文 Hi, thanx for your effort to help me. I just reviewed: Using a CY8C5588AX*-60 ES1 (That's what the Miniprog 3 says) And I red in the Revision Doc for Creator 2: ES1 no longer supported. Might be the error. If you can get hands on a PSoC5 processor module with ES1 you can try. Isn't there an exchange-program to current ESes for the modules? (I reside in Germany, how to???) Regards, Bob |
创建者2的迁移文档明确说明CY8C5688 AXI-060 ES1仍然支持,因为它被交付给客户。
以上来自于百度翻译 以下为原文 The migration document for Creator 2.0 explicitely states that CY8C5588AXI-060 ES1 is still supported, since it was delivered to customers. |
好了,现在我们知道的和以前一样多了。我将安装一个Vista机器上的创建者2,它与一个MixPrim3到一个工具包01a,其中一个工作(测试了CyReal1)PSOC5处理器模块,上面有AsNI1 5588。我会写一个小演示项目,我会告诉你结果。
快乐升级 鲍勃 以上来自于百度翻译 以下为原文 Ok, so now we know as much as before. I'll install creator 2 on a Vista machine which is connected with a Miniprog3 to a Kit 001a with a working (tested with Creator1) PSoC5 processor module with an ES1 5588 on it. I'll write a small demo project and I'll inform you about the results... Happy Upgrading Bob |
是的,错误仍然存在,太糟糕了。
错误消息: 警告:不能设置断点:'C:CyPress 另一个测试区域CR2TestCR2Test.CysN\Meal.C:26’。遇到错误(在目标中没有硬件断点支持)。错误:dg.M90015:调试器在运行期间意外退出。遇到错误(远程通信错误:无错误)。 为了清晰起见,我包含了ReBPONT错误消息,调试器也在没有断点的情况下退出。 项目追加。环境: 赢景 PSoC Creator 2 小型机器人3 KIT 01A CY8C5688 ES1处理器模块 类似项目在同一环境下与PSoC创建者1 SP2协同工作 快乐周末 鲍勃 CR2Test.CyWrk.CaseV01.Zip 913.1 K 以上来自于百度翻译 以下为原文 Yes, the error persists, too bad. Errormessage: Warning: Cannot set breakpoint: 'C:CypressAnother TestareaCr2TestCr2Test.cydsnmain.c:26'. Encountered error (No hardware breakpoint support in the target.). Error: dbg.M0015: Debugger exited unexpectedly during run. Encountered error (Remote communication error: No error.) I included the Breakpont-errormessage only for clarity, the debugger exits without a breakpoint as well. Project appended. Environment: Win Vista PSoC Creator 2 Miniprog 3 Kit 001a Cy8c5588 ES1 - Processor module Similar project works fine with PSoC Creator 1 SP2 under the very same environment Happy weekend Bob
你能检查MixPrim3时钟速度值吗?选择的速度不应超过目标设备的总线时钟速度的1/3倍,而较慢的速度是可能调试的,速度至少应该是1 MHz来编程设备。6兆赫是最高推荐时钟速度。
以上来自于百度翻译 以下为原文 Can you check the Miniprog3 clock speed value? The selected speed should not be more than 1/3 rd the value of Bus clock speed of the target device. While slower speeds are possible for debugging, the speed should be at least 1 MHz to program the device. 6 MHz is the highest recommended clock speed. |
你好,
我也有调试与PSoC Creator 2问题。同样的消息出现:“dg.M90015:调试器在运行期间意外退出。遇到错误(远程通信错误:没有错误。)”。我已经改变了调试速度(低于1/3 BuxLCK),并且仍然。 我用cy8c3866axi-040es2与cy8ckit-001。该装置适当程序但当您尝试更改为调试模式,错误被。 有什么想法吗?谢谢。 以上来自于百度翻译 以下为原文 Hello, I'm also having debug problems with PSoC Creator 2.0. The same message appears: "dbg.M0015: Debugger exited unexpectedly during run. Encountered error (Remote communication error: No error.)". I've changed the Debug speed (lower than 1/3 BUS_CLK) and still. I am using the CY8C3866AXI-040ES2 with the CY8CKIT-001. The device is properly programed but when you try to change to debug mode, the error apears. Any ideas? Thank's. |
我为我解决了这个问题。
您的Windows用户名不包含任何特殊字符(非ASCII)?我的用户名是“jo rg”。当我安装了一个新的úSER(重命名工作不小心:)一切都好。真的花了我几个小时! 鲍勃 以上来自于百度翻译 以下为原文 I solved the problem for me. Does your windows-username contain any special (non ASCII) characters? My username was "Jörg". when I installed a new úser (caution:renaming does NOT work) everything went fine. That did cost me hours, indeed! Bob |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7575浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6124浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7969浏览 2评论
/9
GMT+8, 2025-12-2 20:34 , Processed in 1.774210 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2209
