电子发烧友论坛扫一扫,分享给好友
单个和差分信号有不同的IO标准,如LVCMOS,LVTTL,LVDS,BLVDS。当我决定IO标准时,我应该遵循什么原则?
或者我怎么知道我应该为我的设计使用哪个标准? 非常感谢。 以上来自于谷歌翻译 以下为原文 There are different IO standards for single and differential signals like LVCMOS, LVTTL, LVDS, BLVDS. What principle should I follow when I decide IO standard? Or how can I know which standard I should use for my design? Thanks a lot. |
4个回答
b,
通常,如果您要连接到其他设备,则符合其标准(smae标准连接到相同标准)。 如果你想选择一个标准来使用,你可以选择链接的两端,那么问题是多远和多快? LVDS适用于长电缆,也适用于最高速度(短距离)。 它的噪音也最小(地面反弹)。 LVCMOS标准适用于中速。 使用最低的驱动级别,以您想要的速度执行。 观察正确的信号完整性实践(受控阻抗,终端)。 存储器设备(HSTL,SSTL)有特定的标准,用于那些应用程序。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 b, In general, if you are connecting to another device, you match its standard (smae standard connects to same standard). If you want to choose a standard to use, and you get to choose both ends of the link, then the questions are how far, and how fast? LVDS is good for long cables and is also very good for highest speeds (over shorter distances). It also has the least noise (ground bounce). The LVCMOS standards are good for medium speeds. Use the weakest drive level that performs at the speed you desire. Observe proper signal integrity practices (controlled impedances, terminations). There are specific standards for memory devices (HSTL, SSTL), use those for those applications. Austin Lesea Principal Engineer Xilinx San Jose |
非常感谢,奥斯汀。
除了IO标准之外,似乎我还需要决定IO类型。 据我所知,7系列FPGA的IO类型包括三种类型:HP,HR和GTX。 GTX似乎特定于MGT,但我没有在UG471中获得任何有关它的信息。 对于HR和HP,我应该根据我想要的标准来决定使用哪种类型? 再次感谢。 以上来自于谷歌翻译 以下为原文 Thanks very much, austin. And besides IO standard, it seems I also need to decide IO type. As I know, IO type for 7 series FPGA includes three types: HP, HR, and GTX. GTX seems to be specific for MGT, however I did not get any information about it in UG471. For HR and HP, should I decide which type I want to use based on which standard I want to us? Thanks again. |
HP和HR是IO银行类型,并将银行的功能称为高性能
或高范围。 在这种情况下,性能意味着速度,范围意味着最大IO电压。 一旦为引脚选择了IO标准,就应该将其分配给可以支持的银行 因为该标准,例如LVCMOS25或LVCMOS33必须在HR银行上进行 所需电压。 - Gabor - Gabor 以上来自于谷歌翻译 以下为原文 HP and HR are IO bank types, and refer to the bank's capability as either High Performance or High Range. In this case performance means speed, and range means maximum IO voltage. Once you've picked the IO standard for a pin, you should assign it to a bank that can support that standard, for example LVCMOS25 or LVCMOS33 must go on a HR bank because of the required voltage. -- Gabor -- Gabor |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 07:42 , Processed in 0.616059 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1012
