电子发烧友论坛|
您好,我计划将VSA与我的自动测试软件(用labview编写)集成,用于变送器测试。
用例如下。 VSA将在连接到PSA频谱分析仪的PC上运行。 运行VSA的PC将连接到运行自动测试软件的另一台PC进行发射机测试。 我在这方面有下面提到的问题。 1.)如何使用另一台PC对一台PC进行编程? 2.)在这种情况下,我如何使用SCPI或任何其他方法编程VSA? 3.)最后,是否使用VSA中的SCPI支持所有测量和设置(特别是选项200,300,AYA和BHK支持的测量和设置)? 应用程序需要在VSA中执行所有相关设置,然后使用自动测试软件捕获VSA的测量结果。 期待你的回复。 谢谢。 此致,Asish Jain。 以上来自于谷歌翻译 以下为原文 Hello, I plan to integrate VSA with my automated test software (written in LabVIEW) for transmitter testing. The use case is as follows. VSA will run on a PC connected to PSA spectrum analyzer. And the PC running VSA will be connected to another PC running the automated test software for transmitter testing. I’ve below mentioned queries in this regards. 1.) How will I address one PC using another PC for programming? 2.) In this case, how can I program VSA using SCPI or any other method? 3.) Lastly, are all measurements and settings supported using SCPI in VSA (in particular, the ones supported under option 200, 300, AYA and BHK)? The application requires to do all the relevant settings in VSA and then capture the measurement results of VSA using the automated test software. Looking forward to your reply. Thank you. Regards, Asish Jain. |
1个回答
Hi-SCPI API是唯一可用于在远程PC上访问VSA的方法。
并非所有功能都在SCPI中可用。 有关详细信息,请参阅软件随附的SCPI参考。 软件中还包含SCPI示例程序,它们可以在C: Program Files Agilent 89600软件18.0 89600 VSA Software Examples SCPI Regards中找到 - 以上来自于谷歌翻译 以下为原文 Hi - SCPI API is the only method available to access VSA on a remote PC. Not all functionality is available in SCPI. Please see the SCPI reference included with the software for details. There are also SCPI example programs included with the software and they can be found in C:Program FilesAgilent89600 Software 18.089600 VSA SoftwareExamplesSCPI Regards - |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 06:06 , Processed in 0.873960 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2115
