之前用F1,F2的时候,多通道DMA采样一直很顺
到了F7,就变得好奇怪,在MDK里面设断点运行,ADC数据会更新,但是连续跑的时候,ADC就再也不更新了 /****************************************************************************** * File: drv_adc.c - ADC * * Description: * ADC * revision history: * version 1.0,written by sainty07,2017-01-20 * * Copyright 2006-2008, ALL rights reserved.. ******************************************************************************/ #include "board.h" #include "rtthread.h" static ADC_HandleTypeDef hadc1 = {ADC1}; static rt_timer_t timer_adc1; static ADC_ChannelConfTypeDef sConfig[] = { //{ADC_CHANNEL_9, 1, ADC_SAMPLETIME_15CYCLES, 0}, //{ADC_CHANNEL_7, 1, ADC_SAMPLETIME_15CYCLES, 0}, //{ADC_CHANNEL_11, 1, ADC_SAMPLETIME_15CYCLES, 0}, //{ADC_CHANNEL_12, 1, ADC_SAMPLETIME_15CYCLES, 0}, //{ADC_CHANNEL_13, 1, ADC_SAMPLETIME_15CYCLES, 0}, {ADC_CHANNEL_14, 1, ADC_SAMPLETIME_480CYCLES, 0}, {ADC_CHANNEL_15, 2, ADC_SAMPLETIME_480CYCLES, 0}, //{ADC_CHANNEL_VREFINT, 8, ADC_SAMPLETIME_144CYCLES, 0}, //{ADC_CHANNEL_VBAT, 9, ADC_SAMPLETIME_144CYCLES, 0}, //{ADC_CHANNEL_TEMPSENSOR, 9, ADC_SAMPLETIME_480CYCLES, 0}, }; #define ADC_CH_NUM (sizeof(sConfig)/sizeof(ADC_ChannelConfTypeDef)) volatile uint32_t adc_buf[ADC_CH_NUM] = {0}; void DMA2_Stream0_IRQHandler(void) { // rt_interrupt_enter(); HAL_DMA_IRQHandler(hadc1.DMA_Handle); // rt_interrupt_leave(); } static void adc_read(void * parameter) { int i; //HAL_ADC_Start(&hadc1); // if (HAL_OK == HAL_ADC_PollForConversion(&hadc1, 0)) { uint32_t v = adc_buf[0];//HAL_ADC_GetValue(&hadc1); rt_kprintf("adc: %d ", v); } // HAL_ADC_Start(&hadc1); //if (HAL_OK == HAL_ADC_PollForConversion(&hadc1, 0)) { uint32_t v = adc_buf[1];// HAL_ADC_GetValue(&hadc1); rt_kprintf("%d ", v); } rt_kprintf("rn"); //hadc1.Instance->CR2 |= (uint32_t)ADC_CR2_SWSTART; } void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc) { static DMA_HandleTypeDef hdma_adc1; __HAL_RCC_ADC1_CLK_ENABLE(); __HAL_RCC_DMA2_CLK_ENABLE(); HAL_IoArrayInit(GPIO_Init_ADC1, GPIO_CFG_NUM(GPIO_Init_ADC1)); hdma_adc1.Instance = ADC1_DMA_STREAM; hdma_adc1.Init.Channel = ADC1_DMA_CHANNEL; hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE; hdma_adc1.Init.MemInc = DMA_MINC_ENABLE; hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD; hdma_adc1.Init.MemDataAlignment = DMA_PDATAALIGN_WORD; hdma_adc1.Init.Mode = DMA_CIRCULAR; hdma_adc1.Init.Priority = DMA_PRIORITY_HIGH; hdma_adc1.Init.FIFOMode = DMA_FIFOMODE_DISABLE; __HAL_LINKDMA(hadc, DMA_Handle, hdma_adc1); HAL_DMA_Init(&hdma_adc1); HAL_NVIC_SetPriority(ADC1_DMA_IRQn, NVIC_PRIORITY_ADC1, 0); HAL_NVIC_EnableIRQ(ADC1_DMA_IRQn); } static rt_err_t rt_hw_adc_init(void) { volatile ADC_ChannelConfTypeDef ch; int i; hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4; hadc1.Init.Resolution = ADC_RESOLUTION_12B; hadc1.Init.ScanConvMode = ENABLE; hadc1.Init.ContinuousConvMode = ENABLE; hadc1.Init.DiscontinuousConvMode = DISABLE; hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc1.Init.NbrOfConversion = 2; hadc1.Init.DMAContinuousRequests = ENABLE; hadc1.Init.EOCSelection = ADC_EOC_SEQ_CONV; if (HAL_ADC_Init(&hadc1) != HAL_OK) { return -RT_ERROR; } // for (i = 0; i < ADC_CH_NUM; i++) // { // ch = ; // ch.Rank = i + 1; if (HAL_ADC_ConfigChannel(&hadc1, (ADC_ChannelConfTypeDef *)&sConfig[0]) != HAL_OK) { return -RT_ERROR; } if (HAL_ADC_ConfigChannel(&hadc1, (ADC_ChannelConfTypeDef *)&sConfig[1]) != HAL_OK) { return -RT_ERROR; } // } if(HAL_ADC_Start_DMA(&hadc1, (uint32_t *)&adc_buf[0], ADC_CH_NUM) != HAL_OK) { return -RT_ERROR; } //HAL_ADC_Start(&hadc1); //HAL_ADC_Stop(&hadc1); // timer_adc1 = rt_timer_create("adc1", adc_read, RT_NULL, 100, RT_TIMER_FLAG_PERIODIC); // rt_timer_start(timer_adc1); return RT_EOK; } void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* AdcHandle) { // HAL_ADC_Start_DMA(&hadc1, (uint32_t *)&adc_buf[0], ADC_CH_NUM); { uint32_t v = adc_buf[0];//HAL_ADC_GetValue(&hadc1); rt_kprintf("adc: %d ", v); } // HAL_ADC_Start(&hadc1); //if (HAL_OK == HAL_ADC_PollForConversion(&hadc1, 0)) { uint32_t v = adc_buf[1];// HAL_ADC_GetValue(&hadc1); rt_kprintf("%d ", v); } rt_kprintf("rn"); hadc1.Instance->CR2 |= (uint32_t)ADC_CR2_SWSTART; } int drv_adc1(void) { rt_hw_adc_init(); return 0; } //INIT_BOARD_EXPORT(drv_adc1); |
5个回答
这几句改一下试看看 hadc1.Init.EOCSelection = DISABLE; hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; hdma_adc1.Init.MemDataAlignment =DMA_MDATAALIGN_HALFWORD; 还有:ADC初始化和DMA初始化的顺序也有讲究的。 |
st官网应该有多通道的范例,找找看。
ADC_EOC_SEQ_CONV===》库注释为未来预留设置, 你这里配置为 ADC_EOC_SINGLE_CONV 测试验证下。 |
谢谢上面几位支招,不过还是不行,其实调了一个星期,能试过的配置都试过了,现在再次试了一下,还是不行,不知道是ADC不行,还是DMA有问题
现在用个定时器每次采样一个通道,ADC数据倒有更新 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1328 浏览 1 评论
1070 浏览 0 评论
936 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
5174 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
3974 浏览 1 评论
/9
GMT+8, 2025-12-14 08:13 , Processed in 0.782029 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2028
