电子发烧友论坛|
嗨,我正在尝试与使用RS232通信的电源进行通信。
它不支持SCPI。 目前,我正在尝试使用.NET函数进行通信,这非常繁琐。 有没有人有更好的方法? 一个例子将是伟大的。 以上来自于谷歌翻译 以下为原文 Hi, I'm trying to communicate with a power supply which uses RS232 communication. It does not support SCPI. Currently, I'm trying to use .NET function to communicate which is very tedious. Does anyone have a better method? An example will be great. |
5个回答
当然,您可以通过VEE和IOLIB中包含的“ASRL”使用直接IO。
但是您确实需要要发送的命令。 那么你有可用的命令吗? 对于示例代码等,您必须提供更多输入,例如什么设备,什么样的版本等等......在Vee / help 7examples文件夹中有很多样本。 此外,您可以尝试转到菜单IO /仪器管理器,单击“查找”按钮并希望它可以正常工作。 它甚至可以自动提供一些样品 - 但是对于有限数量的设备 - 主要是安静的东西...... 以上来自于谷歌翻译 以下为原文 For sure you can use the direct IO via "ASRL" which is included in VEE and IOLIB. But you do need the commands you want to send . So do you have the commands available? For sample code and so on you have to supply more input, like what equipment , what vee version and so on... there are a lot of samples in the Vee / help 7examples folder. Additionally you can try to go to the menue IO/Instrument manager, click the find button and hope that it works . It even supplies some sample automatically- but for a limited amount of equipment - mainly agilent stuff... |
嗨dBdetlef,我目前正在使用.NET功能来做到这一点。
但非常乏味。 我试图在直接I / O中使用ARSL但不确定如何设置COM端口以及EOL。 我有要发送的命令列表。 在VEE帮助中找不到示例。 你有我可以参考的文件名吗? 谢谢你,丹尼尔 以上来自于谷歌翻译 以下为原文 Hi dBdetlef, I'm currently using the .NET feature to do it. but very tedious. I tried to use the ARSL in direct I/O but not sure how to set the COM port and also the EOL. I do have the list of commands to send. Can't find the examples in the VEE help. Do you have the file name which I can refer to? Thanks Regards, Daniel |
嗨抱歉,错过了当前使用的附加信息:VEE 9.21 I / O Suite 16 GW Instek PSP-603可编程电源。 以上来自于谷歌翻译 以下为原文 Hi Sorry, Missed out on the additional information, currently using: VEE 9.21 I/O Suite 16 GW Instek PSP-603 Programmable Power Supply. |
我现在尝试搜索一些样本,但实际上,在样本中并不容易找到。
看看示例/手册......无论如何,使用带有ASRL的directIO很容易。 菜单/ IO仪器管理器,那么右侧应该有一个区域。 单击,转到“查找” - 搜索。 您应该拥有所有接口。如果您的ser设备是ASRL0,请使用ASRL0,在开发面板中使用拖放操作。 然后,您可以选择Ser,liek baudrate和8N1的设置数据,依此类推。 您可以通过Write发送命令,并通过“READ”读取答案。 在安静的网站上有一个关于这个的多媒体演示;-)我没有你的设备,因此我无法为此发送精确的样本。 但是附近的一些示例代码......也许还可以查看:http://veeforum.de/benutzung-der-seriellen-schnittstelle-best-practice-t-238.html以查看最佳实践。 例如,对于VEE的新版本,将Seriel1更改为ASRL0。 顺便说一句,更新到VEE9.31! 以上来自于谷歌翻译 以下为原文 I try to search some samples now, but indeed, not easy to find in the samples. Have a look for examples/manual... Anyhow, using directIO with ASRL is easy. Menue/IO Instrument manager, then there should be a area on the right side. Click in , the go to "Find" -search. You should have all interfaces there.Use ASRL0 in case your ser device is ASRL0, use drag and drop in the development panel. Then you can choose your set -up data for the Ser , liek baudrate and 8N1 and so on. You can send commands via Write and read the answers via "READ". There shoudl be a multimedia demonstration about this somewhere on the agilent website ;-) I do not have your device, therefore i can not send exact sample for this. But some sample code nearby ... Perhaps also have a look at : http://veeforum.de/benutzung-der-seriellen-schnittstelle-best-practice-t-238.html to see best practice. Change Seriel1 to ASRL0 for example for the newer versiosn of VEE. By the way, update to VEE9.31 ! 附件
60user176 发表于 2019-2-13 17:53 嗨dBdetlef,谢谢你分享信息。 我会去尝试一下,然后再回复你。 谢谢你的帮助。 以上来自于谷歌翻译 以下为原文 Hi dBdetlef , Thanks for sharing the info. I'll go have a try and get back to you on this. Thanks for helping out. |
只有小组成员才能发言,加入小组>>
250 浏览 0 评论
1863 浏览 0 评论
2753 浏览 1 评论
2656 浏览 1 评论
2477 浏览 5 评论
1863浏览 0评论
431浏览 0评论
253浏览 0评论
/9
GMT+8, 2025-12-12 00:54 , Processed in 1.000505 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
559
