电子发烧友论坛|
我的应用是将我的控制器和GSM部分与我的2轮电池12V 5A的电池连接。我能够用这个电池来切换继电器。一般来说,在使用中,2轮汽车通过整流器在车辆中充电。我的问题是当我的车不在使用时,我如何节省电池的电量?因为控制器和GSM将在电池的完全放电中连续地从电池结果中排出电流。我应该怎么做,我的PIC&GSM将绘制最小电流时,车辆不在使用?
以上来自于百度翻译 以下为原文 My application is to interface my controller & Gsm section with battery of my 2 wheeler battery 12v 5A. I am able to switch relay with this battery. In general, 2 wheeler vehicle's battery charging through rectifier present in vehicle when in use. My question is how do i save power of my battery when my vehicle is not in use.?? As controller & GSM will drain the current continuously from battery results in fully discharge of battery. What should i do that my PIC & GSM will draw minimum current when vehicle is not in use? |
8个回答
如果你开始提到你正在使用哪一个PIC,这会有帮助。它能控制GSM模块的电源吗?你能给我们看一下你的电路板的原理图吗?
以上来自于百度翻译 以下为原文 It would help if you started by mentioning WHICH PIC you are using. Can it control power to the GSM module? Can you show us a schematic of your board? |
我使用的是PIC16F628 A,它工作在3.3V。电源到GSM和PIC是与LM2596调节器IC。通过点击链接可以看到这里的参考图像。
以上来自于百度翻译 以下为原文 I am using pic16f628a which is working on 3.3v. Power to the GSM & PIc is with lm2596 regulator ic . u can see here the reference image by clicking on link. |
是的,而且PIC对于GSM的用途将非常有限。
以上来自于百度翻译 以下为原文 Yep, and that PIC is going to very-very limited for GSM purpose... |
U可以右击图像查看我使用的参考电源
以上来自于百度翻译 以下为原文 u can right click on image to view the reference supply i have used |
什么图像?您还没有发布图像或链接。
以上来自于百度翻译 以下为原文 What image? You have not yet posted an image or a link. |
GSM模块实际需要多长时间进行通信?如果很少,也许这个问题用电子设备而不是软件来解决。例如,一个IO引脚,用来切换MOSFET以在需要使用时向GSM模块供电,然后在完成后再将其关断。然后,如果PIC在所有其他时间处于低功率状态,也许醒过来检查传感器和/或给GSM供电。模块发送或检查是否有任何等待SMS等,当前绘制应该是非常小的。
以上来自于百度翻译 以下为原文 How often is the GSM module actually required for communication? If infrequently, perhaps this problem is solved more so with additional electronics rather than software. For example, an IO pin which is used to switch a MOSFET to supply power to the GSM module when it is required to be used, and then switches it off again once you are done. Then, if the PIC sits in a low power state during all other times, perhaps waking up to check sensors and/or to power up the GSM module to send or check if there are any waiting SMS etc, current draw should be very minimal. |
显然,链接仅仅是一个搜索结果TTPPS://www. GooGel.Co.in……
以上来自于百度翻译 以下为原文 apparently the link was only a search result https://www.google.co.in/...#imgrc=2U-STPSgFpeoNM: |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
503 浏览 0 评论
5812 浏览 9 评论
2350 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3544 浏览 3 评论
1159浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1121浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
888浏览 1评论
503浏览 0评论
/9
GMT+8, 2025-12-13 21:23 , Processed in 1.026401 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
413
