我试图在Spartan3A XC3S700A的垫子中使DELAY_ADJ工作。
但似乎通过改变S1,S2,S3无法调节延迟。 附件是FPGA编辑器的截图,其XDL代码如下, inst“LED0”“IOB”,放置RIOIS_X41Y13 R20,cfg“DELAY_ADJ_ATTRBOX :: VARIABLE DRIVEATTRBOX :: 8 DRIVE_0MA ::#OFF GTSATTRBOX ::#OFF IBUF_DELAY_VALUE :: DLY0 ICEINV ::#OFF ICLK1INV ::#OFF ICLK2INV ::# OFF IDDRIN_MUX :: #OFF IFD_DELAY_VALUE :: DLY0 IFF1 ::#OFF IFF1_INIT_ATTR ::#OFF IFF1_SR_ATTR ::#OFF IFF2 ::#OFF IFF2_INIT_ATTR ::#OFF IFF2_SR_ATTR ::#OFF IFFATTRBOX ::#OFF IFFDMUX ::#OFF IMUX :: 1 IOATTRBOX :: LVCMOS33 IREV_USED ::#OFF ISR_USED ::#OFF MISRATTRBOX ::#OFF MISR_CLK_SELECT ::#OFF O1INV :: #OFF O1_DDRMUX ::#OFF O2INV :: O2_B O2_DDRMUX ::#OFF OCEINV :: #OFF ODDROUT1_MUX ::#OFF ODDROUT2_MUX ::#OFF OFF1 ::#OFF OFF1_INIT_ATTR ::#OFF OFF1_SR_ATTR ::#OFF OFF2 ::#OFF OFF2_INIT_ATTR ::#OFF OFF2_SR_ATTR ::#OFF OFFATTRBOX ::#OFF OMUX :: O2 OREV_USED :: #OFF OSR_USED ::#OFF OTCLK1INV ::#OFF OTCLK2INV ::#OFF PCICE_MUX ::#OFF PCIRDY_MUX ::#OFF PULL ::#OFF REVINV ::#OFF SEL_MUX :: 0 SLEW :: SLOW SRINV ::#OFF SUSPEND :: 3STATE T1INV :: T1 T2INV ::#OFF TCEINV ::#OFF TFF1 ::#OFF TFF1_INIT_ATTR ::#OFF TFF1_SR_ATTR ::#OFF TFF2 ::#OFF TFF2_INIT_ATTR ::#OFF TFF2_SR_ATTR: :#OFF TFFATTRBOX :: #TO TM :: T1 TREV_USED ::#OFF TSMUX ::#OFF TSR_USED ::#OFF T_USED ::#OFF DELAY_ADJ_BBOX:LED0.DELAY_ADJ:INBUF:IOBUF_inst / IBUF:OUTBUF:IOBUF_inst / OBUFT: PAD:LED0:“; 任何帮助,将不胜感激... Ĵ 以上来自于谷歌翻译 以下为原文 I tried to make DELAY_ADJ work in a pad in Spartan3A XC3S700A. But it seems that the delay is not adjustable by changing S1, S2, S3. Attached is the screenshot from FPGA editor, and its XDL code is as follows, inst "LED0" "IOB",placed RIOIS_X41Y13 R20 , cfg " DELAY_ADJ_ATTRBOX::VARIABLE DRIVEATTRBOX::8 DRIVE_0MA::#OFF GTSATTRBOX::#OFF IBUF_DELAY_VALUE::DLY0 ICEINV::#OFF ICLK1INV::#OFF ICLK2INV::#OFF IDDRIN_MUX::#OFF IFD_DELAY_VALUE::DLY0 IFF1::#OFF IFF1_INIT_ATTR::#OFF IFF1_SR_ATTR::#OFF IFF2::#OFF IFF2_INIT_ATTR::#OFF IFF2_SR_ATTR::#OFF IFFATTRBOX::#OFF IFFDMUX::#OFF IMUX::1 IOATTRBOX::LVCMOS33 IREV_USED::#OFF ISR_USED::#OFF MISRATTRBOX::#OFF MISR_CLK_SELECT::#OFF O1INV::#OFF O1_DDRMUX::#OFF O2INV::O2_B O2_DDRMUX::#OFF OCEINV::#OFF ODDROUT1_MUX::#OFF ODDROUT2_MUX::#OFF OFF1::#OFF OFF1_INIT_ATTR::#OFF OFF1_SR_ATTR::#OFF OFF2::#OFF OFF2_INIT_ATTR::#OFF OFF2_SR_ATTR::#OFF OFFATTRBOX::#OFF OMUX::O2 OREV_USED::#OFF OSR_USED::#OFF OTCLK1INV::#OFF OTCLK2INV::#OFF PCICE_MUX::#OFF PCIRDY_MUX::#OFF PULL::#OFF REVINV::#OFF SEL_MUX::0 SLEW::SLOW SRINV::#OFF SUSPEND::3STATE T1INV::T1 T2INV::#OFF TCEINV::#OFF TFF1::#OFF TFF1_INIT_ATTR::#OFF TFF1_SR_ATTR::#OFF TFF2::#OFF TFF2_INIT_ATTR::#OFF TFF2_SR_ATTR::#OFF TFFATTRBOX::#OFF TMUX::T1 TREV_USED::#OFF TSMUX::#OFF TSR_USED::#OFF T_USED::#OFF DELAY_ADJ_BBOX:LED0.DELAY_ADJ: INBUF:IOBUF_inst/IBUF: OUTBUF:IOBUF_inst/OBUFT: PAD:LED0: " ; any help would be appreciated... J |
2个回答
我不明白你说延迟是不可调整的。
你意识到了这一点 这个延迟是输入信号而不是输出到焊盘? 斯巴达3A没有 有输出延迟元件,只有输入延迟。 - Gabor - Gabor 以上来自于谷歌翻译 以下为原文 I don't understand whay you say the delay is not adjustable. You do realize that this delay is on the input signal and not the output to the pad? Spartan 3A does not have output delay elements, only input delays. -- Gabor -- Gabor |
gszakacs写道:
我不明白你说延迟是不可调整的。 你意识到了这一点 这个延迟是输入信号而不是输出到焊盘? 斯巴达3A没有 有输出延迟元件,只有输入延迟。 - Gabor 是的...现在我可以通过s1 s2 s3控制其输入延迟。 我所做的是将“IBUF_DELAY_VALUE :: DLY0”的值更改为“IBUF_DELAY_VALUE :: DLY9”。 但是,我不太确定“DLY0”或“DLY9”是什么意思? 我找不到谈论这些价值观的文件...... 谢谢... 以上来自于谷歌翻译 以下为原文 gszakacs wrote:yeah... Now I can control its input delay by s1 s2 s3. What I did is changing the value of "IBUF_DELAY_VALUE::DLY0" to "IBUF_DELAY_VALUE::DLY9". However, I am not quite sure what the "DLY0" or "DLY9" mean? and I could not find a document talking about these values... Thanks... |
只有小组成员才能发言,加入小组>>
2179 浏览 7 评论
2617 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2212 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
450浏览 1评论
1540浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2184浏览 0评论
516浏览 0评论
1658浏览 0评论
GMT+8, 2024-5-14 10:02 , Processed in 1.187803 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
