急求AIC3204的麦克风输入程序,用ezdsp5515例子,麦克风始终输入不了语音信号~求指教!
4 个讨论
补上源程序代码块:
/* Configure AIC3204 */ AIC3204_rset( 0, 0 ); // Select page 0 AIC3204_rset( 1, 1 ); // Reset codec AIC3204_rset( 0, 1 ); // Select page 1 AIC3204_rset( 1, 8 ); // Disable crude AVDD generation from DVDD AIC3204_rset( 2, 1 ); // Enable Analog Blocks, use LDO power AIC3204_rset( 0, 0 ); // Select page 0 /* PLL and Clocks config and Power Up */ AIC3204_rset( 27, 0x0d ); // BCLK and WCLK is set as o/p to AIC3204(Master) AIC3204_rset( 28, 0x00 ); // Data ofset = 0 AIC3204_rset( 4, 3 ); // PLL setting: PLLCLK <- MCLK, CODEC_CLKIN <-PLL CLK AIC3204_rset( 6, 7 ); // PLL setting: J=7 AIC3204_rset( 7, 0x06 ); // PLL setting: HI_BYTE(D=1680) AIC3204_rset( 8, 0x90 ); // PLL setting: LO_BYTE(D=1680) AIC3204_rset( 30, 0x88 ); // For 32 bit clocks per frame in Master mode ONLY // BCLK=DAC_CLK/N =(12288000/8) = 1.536MHz = 32*fs AIC3204_rset( 5, 0x91 ); // PLL setting: Power up PLL, P=1 and R=1 AIC3204_rset( 13, 0 ); // Hi_Byte(DOSR) for DOSR = 128 decimal or 0x0080 DAC oversamppling AIC3204_rset( 14, 0x80 ); // Lo_Byte(DOSR) for DOSR = 128 decimal or 0x0080 AIC3204_rset( 20, 0x80 ); // AOSR for AOSR = 128 decimal or 0x0080 for decimation filters 1 to 6 AIC3204_rset( 11, 0x82 ); // Power up NDAC and set NDAC value to 2 AIC3204_rset( 12, 0x87 ); // Power up MDAC and set MDAC value to 7 AIC3204_rset( 18, 0x87 ); // Power up NADC and set NADC value to 7 AIC3204_rset( 19, 0x82 ); // Power up MADC and set MADC value to 2 /* DAC ROUTING and Power Up */ AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 12, 0x08 ); // LDAC AFIR routed to HPL AIC3204_rset( 13, 0x08 ); // RDAC AFIR routed to HPR AIC3204_rset( 0, 0x00 ); // Select page 0 AIC3204_rset( 64, 0x02 ); // Left vol=right vol AIC3204_rset( 65, 0x00 ); // Left DAC gain to 0dB VOL; Right tracks Left AIC3204_rset( 63, 0xd4 ); // Power up left,right data paths and set channel AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 16, 0x00 ); // Unmute HPL , 0dB gain AIC3204_rset( 17, 0x00 ); // Unmute HPR , 0dB gain AIC3204_rset( 9, 0x30 ); // Power up HPL,HPR AIC3204_rset( 0, 0x00 ); // Select page 0 USBSTK5515_wait( 500 ); // Wait /* ADC ROUTING and Power Up */ AIC3204_rset( 0, 1 ); // Select page 1 AIC3204_rset( 0x34, 0x30 ); // STEREO 1 Jack // IN2_L to LADC_P through 40 kohm AIC3204_rset( 0x37, 0x30 ); // IN2_R to RADC_P through 40 kohmm AIC3204_rset( 0x36, 3 ); // CM_1 (common mode) to LADC_M through 40 kohm AIC3204_rset( 0x39, 0xc0 ); // CM_1 (common mode) to RADC_M through 40 kohm AIC3204_rset( 0x3b, 0 ); // MIC_PGA_L unmute AIC3204_rset( 0x3c, 0 ); // MIC_PGA_R unmute AIC3204_rset( 0, 0 ); // Select page 0 AIC3204_rset( 0x51, 0xc0 ); // Powerup Left and Right ADC AIC3204_rset( 0x52, 0 ); // Unmute Left and Right ADC AIC3204_rset( 0, 0 ); USBSTK5515_wait( 200 ); // Wait /* I2S settings */ I2S0_SRGR = 0x0; I2S0_CR = 0x8010; // 16-bit word, slave, enable I2C I2S0_ICMR = 0x3f; // Enable interrupts 以上配置有错吗 |
只有小组成员才能发言,加入小组>>
173 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1916 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3670 浏览 4 评论
5042 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1741 浏览 1 评论
CC3100BOOST使用CC3200lunchXL进行烧录
693浏览 2评论
741浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
714浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1211浏览 1评论
1797浏览 1评论
GMT+8, 2024-5-15 18:11 , Processed in 1.002436 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
