电子发烧友论坛|
大家好,
我正在寻找一种协议,用于单独的FPGA /板与FPGA之间的通信(有限数量的引脚/串行高速通信似乎是最好的解决方案),我想知道哪一个更适合这项任务。 我已经听说过有关PCI-E的更多信息,所以我假设有更多的支持它,还有带嵌入式PCI-E模块的FPGA,另一方面,RapidIO似乎更简单,开销更低。 你能推荐我其中一个(或者其他一些协议)吗? 最好的祝福, 多米尼克 以上来自于谷歌翻译 以下为原文 Hi all, I'm looking for a protocol to use for communication between separate FPGAs/board with FPGAs (with limited number of pins/serial high speed communication seems the best solution) and I wonder which one is better suited for this task. I've heard more about PCI-E so I assume there's more support for it also there are FPGAs with embedded PCI-E blocks, on the other hand RapidIO seems to be simpler and with lower overhead. Can you recommend me one of them (or maybe some other protocol)? Best regards, Dominik |
6个回答
你也可以看一下极光。
这可能是最简单的选择。 http://www.xilinx.com/products/design_resources/conn_central/grouping/aurora.htm 核心在coregen中可用。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 You might look at aurora as well. It might be the simplest option. http://www.xilinx.com/products/design_resources/conn_central/grouping/aurora.htm The cores are available in coregen. View solution in original post |
所有的FPGA都是Xilinx?光纤还是铜?流媒体或数据包?你的最大字节数是多少?
------------------------------------------“如果它不起作用 模拟,它不会在板上工作。“ 以上来自于谷歌翻译 以下为原文 Are all the FPGAs Xilinx? Fibre or copper? Streaming or packet? What is your max byte/s? ------------------------------------------ "If it don't work in simulation, it won't work on the board." |
嗨,
所有FPGA都将来自Xilinx(可能是Virtex 6),铜缆通信(电缆或PCI-E边缘),数据包大约1KB,400-800 MB / s就足够了。 多米尼克 以上来自于谷歌翻译 以下为原文 Hi, All FPGAs will be fro Xilinx (Virtex 6 probably), communication on copper (cable or PCI-E edge), packets ~1KB, 400-800 MB/s would be enough. Dominik |
你也可以看一下极光。
这可能是最简单的选择。 http://www.xilinx.com/products/design_resources/conn_central/grouping/aurora.htm 核心在coregen中可用。 以上来自于谷歌翻译 以下为原文 You might look at aurora as well. It might be the simplest option. http://www.xilinx.com/products/design_resources/conn_central/grouping/aurora.htm The cores are available in coregen. |
有了这些限制,我再次提出Aurora的建议。
我们将它用于3.125Gb / s的板间通信。 ------------------------------------------“如果它不起作用 模拟,它不会在板上工作。“ 以上来自于谷歌翻译 以下为原文 WIth those constraints, I second the suggestion of Aurora. We are using it for inter-board communications at 3.125Gb/s. ------------------------------------------ "If it don't work in simulation, it won't work on the board." |
是的,这个看起来很有趣。
谢谢, 多米尼克 以上来自于谷歌翻译 以下为原文 Yes, this one looks quite interesting. Thanks, Dominik |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1197浏览 1评论
/9
GMT+8, 2025-12-13 22:08 , Processed in 0.718309 second(s), Total 52, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1735
