嗨!
我在DR-Joel的一篇回应中读到:“所有Agilent VNA中的扫描平均值遵循以下规则:New_Data_Displayed =(New_Data / N)+ Old_displayed_data *(N-1)/ N”这意味着幅度和相位将是平均值。 对于某些N,幅度将变得非常大并且变换为dB。 使用相同规则进行平均相位:New_Data_Displayed =(New_Data / N)+ Old_displayed_data *(N-1)/ N“?或者您使用此规则平均Inphase和正交相位值?感谢您的帮助。 以上来自于谷歌翻译 以下为原文 Hi! I read in one Response of DR-Joel : " Sweep averaging in all Agilent VNA follows the rule: New_Data_Displayed=(New_Data/N)+Old_displayed_data*(N-1)/N" That means the Amplitude and Phase will be Averaged. The amplitude will be avereged for some N and transformed to dB. Do es the Phase Averaged with the Same Rule :New_Data_Displayed=(New_Data/N)+Old_displayed_data*(N-1)/N"? or you average the Inphase and Quadrature-phase Value with this Rule? Thank you for your Help. |
1个回答
对于正常比率测量(即S-参数),该方程应用于每个测量的基础复杂数据,并且在平均后完成显示的最终格式化(改变为LogMag或相位)。
对于单接收机测量(即功率测量),幅度和相位分别平均,然后在最终格式化之前组合成复数。 以上来自于谷歌翻译 以下为原文 for normal ratio measurements (i.e S-Parameters) that equation is applied to the underlying complex data for each measurement and the final formatting for display (changing to LogMag or Phase) is done after averaging. for single receiver measurements (i.e power measurements), the magnitude and phase are averaged separately and then combined back into a complex number before final formatting. |
只有小组成员才能发言,加入小组>>
291 浏览 0 评论
1871 浏览 0 评论
2757 浏览 1 评论
2658 浏览 1 评论
2478 浏览 5 评论
1871浏览 0评论
434浏览 0评论
291浏览 0评论
/9
GMT+8, 2025-12-15 03:48 , Processed in 0.782911 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7188
