电子发烧友论坛|
我为我的自定义硬件创建了一个BSP。我遵循了教程并编辑了文本文件,(BSP.HCONFIG)。如果你有很多定义的话,所有这些都需要完全格式化,而且可能相当冗长。(1)有一种方法使用PIN映射器函数来创建这个文件,而不是手动操作。(2)在所有的例子中,唯一被定义的PIN是GPIO上的LED /按钮之类的东西。与外围设备相关的PIN(例如UART或以太网端口)似乎仍然是未命名的或未定义的,然后当您在别处定义它们时,它们会被打开。这些港口的命名有什么害处吗?PIN映射器可以让你选择它们…期待你的评论。
以上来自于百度翻译 以下为原文 recnetly i created a BSP for my custom hardware.. I followed the tutorial and edited the text files, ( bsp.hconfig) as it described.. It all needs to be perfectly formatted and could be quite lengthy if you had lots of defintions. (1) Is there a way to use the pin mapper function to create this file, rather than doing it manually.. (2) In all the examples, the only pins that seem to get defined are things like leds/buttons on GPIO.. Things like the pins associated with a periphal ( such as a UART or Ethernet port ) seem to remain unnamed or undefined and they then get turned on when you defined them elsewhere... Is there any hARM in naming these ports? the Pin mapper lets you select them... Looking foward to your comments. |
7个回答
我认为有办法导入这些设置,但我不确定我的头。您可以包括PPS功能,如以太网和UART。看看你的项目的MHC文件的提示。今天晚些时候我会发布一个我使用的BSP作为例子。
以上来自于百度翻译 以下为原文 I think there is a way to import those settings, but I'm not sure off the top of my head. You CAN include PPS functions like Ethernet and UART. Take a look at your project's mhc file for hints. I'll post a bsp that I use as an example later today. |
嗨,B祝福,你对微软芯片与GFX的协调似乎足够了吗?你能告诉我如何在微芯片和谐2.04中用PIC32 MX和SSD1963GFX控制器创建BSP吗?谢谢卡兰
以上来自于百度翻译 以下为原文 Hi bblessing, Seems you have quite enough on Microchip Harmony with GFX? Can you advise me how create BSP with PIC32MX and SSD1963 GFX Controller in Microchip Harmony 2.04? Thanks Karan |
创建自定义BSP在2.xx和声版本中被简化。不需要创建新文件,也不需要手动编码步骤!MHC帮助您图形化地创建定制的BSP。“第一卷:开始使用MPLAB和谐& GT板支持包帮助&使用BSP>创建自定义初始板配置”的和谐帮助将给您如何操作的基本指导。今年的美国硕士(H)现在有了一个基本的和谐类,其中一个实验室在使用MHC创建定制的BSP。
以上来自于百度翻译 以下为原文 Creating custom BSP is simplified in 2.xx Harmony releases. No need to create new files and no manual coding steps! MHC helps you to create custom BSP graphically. Section "Volume I: Getting Started With MPLAB Harmony > Board Support Packages Help > Using a BSP > Creating Custom Initial Board Configurations" of Harmony help would give you basic instructions on how to do it. This year US MASTERs(which is happening now) has basic Harmony class where one of the lab was on creating custom BSP using MHC. It worked like charm! |
你好图腾,你可以检查下面的链接截图吗?http://www. McCys.com……09141和FP=1和P = 2剩下什么?创建BSP?---卡兰
以上来自于百度翻译 以下为原文 Hello Totem, Can you check screenshots as below link.? http://www.microchip.com/...09141&fp=1&p=2 What left ? for creating BSP ? --- Karan |
卡兰,我必须检查图腾概述的方法,因为我模糊地记得读过它。至于我所做的,我通常采用迭代的方法来创建一个BSP。你应该做的第一件事是找出BS/CONFIG中的哪些DS文件对应于你的处理器。您将在这里找到一个HCONFIG文件的列表:C:Microchip HealthV2Y03B实用工具MHCCONFIG。只要找到你的处理器,打开它,DS文件的名字就会排在前10行左右。你最终会把你的BSP信息添加到那个文件中,这样它就会出现。需要注意的两件事是:让您的自定义板默认位于DSXXXX文件的顶部,您可能需要在该文件的底部添加一些逻辑来覆盖一些常见的特性。至于BSP本身,复制一个您认为类似于您的项目。BSP.HCONFIG是您将花费大部分时间进行黑客攻击的文件。然而,在你做任何事情之前,你需要重新命名一些东西。我建议使用TeTPad或类似的东西来查找和替换所有的东西,而不是自己动手。假设您已经启动了一个项目,请查看生成的MHC文件。你会发现很多东西可以在你的BSP中重复使用。我不仅增加了PIN的名称,而且还增加了PPS设置、方向、PULUPS、驱动程序选择/设置、堆栈选择等。从一个大的角度来看,我将启动一个项目,启用计时器服务,并使用SysStMRMyDelayMS和SysStTMR.DelayStaseGET函数来创建延迟,以便我可以tog。拨弄一个别针在示波器上看,如果切换频率匹配,那么我马上就知道一些事情。我知道我的时钟设置是有序的,可能是我的配置位,当然是计时器系统服务。然后我可以从MHC文件中偷走这些设置并把它们放入BSP中。这意味着我可能不再需要重新访问配置位。从这里开始,我将向项目中添加一些东西并逐一测试。当一些东西工作时,我会回去把它添加到BSP文件中。为了确保BSP做它应该做的事情,我会重新启动MHC,而不在提示时选择一个配置文件。然后我将检查BSP,因为我的BSP是前面所说的默认值,如果我做的正确的话,我想要的所有设置都将被填入。在你的情况下,我不能真正强调这个缓慢而迭代的方法来完成一个项目。几乎每一次我开始一个新的项目而不做这件事,我就陷入困境,并开始假设事情是真的不是这样。由于图形堆栈非常复杂,您需要消除所有的疑虑。你已经很好地选择了一个支持的图形处理器,希望你已经把硬件从一些微芯片演示板复制到了字母。这样,当事情不一定解决的时候,你可以消除硬件。图腾指出的方法和和谐文献的大纲,可能比我所写的要好得多。但是,你会对BSP有一个很好的理解,这对你将来会有帮助。有一个坚实的BSP为你的项目,无论你是如何获得它是远远优于从零开始每一个项目。最后,不要让免费的模板语言吓唬你。在Microchip前面有明确的文档,在大多数情况下,通过观察它在MHC中的操作,然后查看相关的HCONFIG和FTL文件,可以看出它是如何运作的。
以上来自于百度翻译 以下为原文 @Karan, I'll have to check out the method that Totem has outlined, as I vaguely recall reading about it. As for what I do, I generally take an iterative approach to creating a BSP. The first thing that you should do is find out which one of those DS files in bsp/config corresponds to your processor. You'll find a list of hconfig files here: C:microchipharmonyv2_03butilitiesmhcconfig. Just look for your processor, open it, and the DS file name will be in the first 10 lines or so. You will ultimately add your bsp information to that file so that it shows up. A couple of things to watch out for are the following: make your custom board the default near the top of the DSxxxx file and you may need to add some logic to the very bottom of that file to override some of the _COMMON features. As for the bsp itself, copy one that you deem to be similar to your project. bsp.hconfig is the file that you'll spend most of your time hacking away at. Before you do anything, though, you'll need to rename some things. I would suggest using textpad, or something similar, to find and replace everything without doing it yourself. Supposing that you have started a project already, take a look at the generated mhc file. You'll find that a lot of those things can be reused in your bsp. I've added not just names of pins, but pps settings, direction, pullups, driver selection/settings, stack selection, etc. From a big picture standpoint I'll start a project, enable the timer service, and use the SYS_TMR_DelayMS and SYS_TMR_DelayStatusGet functions to create delays so that I can toggle a pin. Looking at this on an oscilloscope, if the toggle frequency matches then I know quite a few things immediately. I know that my clock settings are in order, probably my configuration bits, and certainly the timer system service. I can then poach those settings from the mhc file and put them into the bsp. This means I probably won't have to revisit the configuration bits again. From here, I'll start adding things to the project and testing them one by one. When something works, I'll go back and add it to the bsp files. To ensure that the bsp does what it should, I'll restart the MHC and NOT select a configuration file when prompted to do so. I'll then check bsp and, since my bsp is the default as outlined earlier, all of the settings that I want will be filled in if I've done it correctly. In your situation, I can't really stress this painstakingly slow, iterative approach to a project enough. Nearly every time I've started a new project without doing this I've gotten bogged down and started assuming things were working that really weren't. This has been true even pre-Harmony. Since the graphics stack is pretty complicated, you'll want to remove all doubt. You've done well choosing a supported graphics processor and hopefully you've copied the hardware from some Microchip demo board to the letter. This way you can eliminate the hardware when things aren't necessarily working out. The approach that Totem noted, and the Harmony documentation outlines, is probably far preferable to that which I have written. However, you'll get a pretty good understanding of bsps that will help you in the future. Having a solid bsp for your project regardless of how you obtained it is FAR preferable to starting every project from scratch. Finally, don't let the free template language scare you. There is definitely documentation from Microchip on that front and in most cases it's pretty simpl to see how it functions by observing its operation in the MHC, and then looking at the related hconfig and ftl files. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:06 , Processed in 0.856853 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5325
