假设我的数字芯片 - FPGA输入或其他方面的超调(正负)超过1V。
芯片长时间会发生什么? 输入端有保护二极管。 二极管会放弃吗? 利用快速边沿速率,二极管甚至不会抑制过冲。 如果芯片完全失效,芯片如何失效? 以上来自于谷歌翻译 以下为原文 Say I have overshoot (both positive and negative) beyond 1V at the input of my digital chip- FPGA or otherwise. What happens to the chip over long time? There are protection diodes at the input. Will the diodes give up? With fast edge rates, the diodes don't even clamp the overshoot. How does the chip fail, if it fails at all? |
2个回答
一般来说,两个轨道的钳位二极管仅在指定为“PCI”的IO处“有效”。
因此,钳位二极管通常称为“PCI钳位二极管”。 但钳位二极管因FPGA器件系列而异,并不普遍适用。 您定位的是哪个设备系列? 通过适度的电流和适度的过冲,钳位二极管应该保持。 理解IO性能(包括钳位二极管)的最佳选择是使用可下载的IBIS模型来模拟它们。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Generally speaking, there are clamp diodes for both rails "active" only for IOs designated as "PCI". Hence the clamp diodes are generically known as "PCI clamp diodes". But the clamp diodes vary by FPGA device family, and do not apply universally. Which device family are you targeting? With modest currents and modest overshoot, the clamp diodes should hold. Your best bet for understanding the performance of the IOs - including clamp diodes - is to simulate them using the downloadable IBIS models. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
每个FPGA系列与其他FPGA系列略有不同,因此您的问题的答案在于您正在使用的FPGA系列数据手册中的“绝对最大额定值”表。
如果超过这些条件,则可能导致损坏。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Each FPGA family is a bit different from the others, so the answer to your question lies in the "Absolute Maximum Ratings" table in th data sheet for the FPGA family that you are using. If you exceed these conditions then damage can result. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
只有小组成员才能发言,加入小组>>
2420 浏览 7 评论
2823 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2294 浏览 9 评论
3374 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2461 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1165浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
585浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
451浏览 1评论
2005浏览 0评论
729浏览 0评论
GMT+8, 2024-12-23 11:11 , Processed in 1.491415 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
