电子发烧友论坛|
嗨,我在模拟在布局中建模和模拟的组件时出错,并插回到ADS 2011.10的原理图中。
关于从布局到原理图彼此不对应的引脚,我收到错误。 我遵循了从ADS文档插入组件的概述说明,但仍未找到解决方案。 以下图片概述了这些问题:http://imgur.com/a/JeCOo谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I am having an error on simulating a component modeled and simulated in the layout and inserted back into the schematic for ADS 2011.10. I get an error regarding the pins not corresponding to each other from the layout to the schematics. I have followed the outlined instructions for inserting components from ADS docs but still have yet to find a solution. The following pics outline the issues: http://imgur.com/a/JeCOo Thank you. |
3个回答
感谢您的答复。
我尝试更改模型设置的设置,我仍然得到相同的错误。 我玩了很多,仍然没有运气。 这是我用于模拟的错误消息和设计设置:http://imgur.com/k1QNFxI看起来模拟没有识别布局窗口中的两个放置的引脚? (错误说示原理图和布局中的2个引脚和0个引脚)任何想法? 以上来自于谷歌翻译 以下为原文 Thanks for your response. I tried changing the settings for the model settings and I still get the same error. I played with it quite a bit and still no luck. Here's the error messages and design settings I used for simulation: http://imgur.com/k1QNFxI Looks like the simulation doesn;t recognize the two placed pins inside the layout window? (error says 2 pins and 0 pins in schematic & layout) Any ideas? |
test_lib:test cell的原理图是否为空? 我怀疑它可能是因为你想使用emModel进行模拟。 如果为空,只需删除该视图即可。 你不需要它。 通过调整Heirarchy策略可能有一些方法可以产生相同的效果,但删除原理图视图是最简单的解决方案。 以上来自于谷歌翻译 以下为原文 Is the schematic view of your test_lib:test cell empty? I suspect it may be as you are wanting to use the emModel for simulation. If it is empty simply delete that view. You don't need it. There may be ways of having the same effect by adjusting the Heirarchy Policy but deleting the schematic view is the easiest solution. |
411easdd*** 发表于 2019-1-24 13:31 谢谢。 删除原理图解决了我的问题。 以上来自于谷歌翻译 以下为原文 Thank you. Deleting the schematic solved my issue. |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 14:52 , Processed in 0.537568 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2938
