你好。
硬件平台:TMS320C6747,50M晶振,主频300M; 软件平台:CCS5.5,SYS/BIOS 6.37.5.35,XTOOLS 3.25.6.96 BIOS使能CLOCK、tiMER、还有TimeStamp组件,确认Timer0和Timer1的输入频率为晶振频率50M,在启动BIOS前创建一个Clock: Error_init(&eb); Clock_Params_init(&clkParams); clkParams.period = 5; clkParams.startFlag = false; gs_clk = Clock_create(ClockSwiHandler, 100, &clkParams, &eb); Assert(NULL != gs_clk); 启动Clock_start()该clock后,通过串口输出每次运行时的TimeStamp,发现每次的时间间隔(前后TimeStamp差分)并不是预期的5ms,而是约5.005ms。 还请TI的工程师分析一下这个问题。 ------------------------------------------------------------------------------------------------------ 使用Timer1_34的HWI来进行相同的处理,发现如下现象: void timer1_setup(void) [ static const uint32_t TIMER_PERIOD12 = 50000000u/1000u - 1u; static const uint32_t TIMER_PERIOD34 = 50000000u/200u - 1u; tmr1Regs->TCR = 0; tmr1Regs->TGCR = 0; tmr1Regs->TGCR |= 0x04; tmr1Regs->TGCR |= 0x03; tmr1Regs->PRD12 = TIMER_PERIOD12; tmr1Regs->TIM12 = 0; tmr1Regs->PRD34 = TIMER_PERIOD34; tmr1Regs->TIM34 = 0; tmr1Regs->TCR &= ~0x1000100; tmr1Regs->TCR |= 0x800080; ] 上述配置的Timer可以产生预期间隔的中断,前后帧差分后的误差小于1us(最小分辨率) 而周期不减1: static const uint32_t TIMER_PERIOD12 = 50000000u/1000u static const uint32_t TIMER_PERIOD34 = 50000000u/200u; ... 产生的现象和使用SYS/BIOS CLOCK模块是相似的。 还请确认下是否是CLOCK模块配置时候减1的问题(按照datasheet的描述应该是减1)。 |
5 个讨论
Hi,
Let's assume the Clock module is configured to 1ms and you create a new Clock instance (call it foo) to go off every 5 ticks. Let's say you call Clock_start at 10.5 milliseconds after you call BIOS_start. When does foo get called? 15 (+small delta) ms foo will be called. Two key points here - This is because the tick count was 10 when the Clock instance was started. 10 + 5 is 15. - There is a small delta * Since the kernel might be doing work on the Clock tick (e.g. making a task ready since Task_sleep expired) * There might be other Clock instances to process first * When the timer interrupt fires, by default a Hwi runs that posts a Swi. The Swi is where all the above work actually occurs. So this adds some overhead. 20 (+small delta) ms foo will be called. 25 (+small delta) ms foo will be called. ... |
kfkdfgd 发表于 2019-1-24 07:38 感谢你的关注,这里我简要描述下当时的状态: 1)确实还有其他HWI存在,因为UART是中断接收/中断发送的(uartIsr处理HWI,比较耗时的处理放在uartTxSwi和UartRxSwi中,SWI的优先级设定为3),共3个UART全双工工作; 2)当时只有一个5ms的Clock实例运行,我需要一个200HZ的周期事件,显然硬件定时器HWI也能满足,但我不希望HWI太多,所以想试试Clock模块; 3)200HZ周期事件CLOCK模块或TIMER的HWI所指向的回调函数(可能不叫回调函数)会调用Mailbox_post(midGiDataSrc, (Ptr)&msg, BIOS_NO_WAIT),打时间标记是在另一个任务中使用Timestamp模块提供的API,Timestamp_get64(),5ms的时间间隔和5.005ms的时间间隔就发生在使用TIMER的HWI和使用CLOCK模块上,其他的条件是一样的,所以我会怀疑Clock模块和Timer的HWI的差别; 4)按照以往的调试经验,不使用硬件方法(硬件TIMER中断或外部FPGA中断)去追求us级别的定时精度是不实际的,而当时的环境也不够纯净,存在多个HWI、SWI,在打timestamp之前还发生Mailbox_post以及任务的切换; 最后还是感谢你们的关注。 |
只有小组成员才能发言,加入小组>>
340 浏览 1 评论
533 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
777 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
653 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1132 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
63浏览 29评论
162浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
253浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
203浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
60浏览 13评论
GMT+8, 2024-12-23 23:28 , Processed in 1.058695 second(s), Total 71, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
