电子发烧友论坛|
大家好,我有N8973 NFA,需要测量混音器(下变频器)的噪声系数。
RF为700至900 MHz。 IF为10 -100 MHz。 我需要测量上边带和下边带。 我也需要在温度范围内这样做。 我将使用ESG或MXG信号发生器作为LO源。 我需要将数据作为IF频率的函数呈现(四条曲线,RF = 700,900 MHz,LO swpet作为上部和下部)。 由于IF频率,滤波是绝对必须的。 我有以下想法:1)双边带测量固定LO。 无需RF滤波器。 在LO上使用带通滤波器。 如果需要,打破IF频段,可以使用低通滤波器来抑制LO信号。 问题是我需要的数据仅为700和900 MHz,但IF每10 MHz(或10点)步进一次。 因此,我需要40次校准和测量。 2)固定射频。 我可以在RF上设置带通滤波器(BW 5%或35到45 MHz),这样4 MHz是平坦的,信号在20 MHz偏移时下降20 dB(我意识到我将无法测量10 MHz) 。 我可以在IF上使用低通滤波器,在这种情况下我只需要四次校准和测量。 NFA仅具有固定的LO /扫频IF或扫频LO /固定IF模式。 不确定如何设置NFA。 (我确实打电话到呼叫中心,但我想我还是会问这里)。 任何评论(赞成,赞成)或新想法都会很棒。 Michael J. Virostko美国马萨诸塞州韦斯特福德综合设备技术公司首席产品应用工程师 以上来自于谷歌翻译 以下为原文 Hello All, I have a N8973 NFA and need to measure the noise figure on a mixer (downconverter). The RF is 700 to 900 MHz. The IF is 10 -100 MHz. I need to measure both the upper and lower sideband. I also need to do this over temperature. I will be using a ESG or MXG signal generator for the LO source. I need the data to be presented as a function of IF frequencies (four curves, RF = 700, 900 MHz, LO swpet as both the upper and lower). Filtering is an absolute must due to the IF frequency. I have the following ideas: 1) Double Side band Measurement with a fixed LO. No RF filter needed. Use a band pass filter on the LO. IF needed, break the IF band up so low pass filters can be use to reject the LO signal. Issue is I need data for only 700 and 900 MHz but with the IF stepped every 10 MHz (or 10 points). Therefore I need 40 calibrations and measurements. 2) Fixed RF. I can set a bandpass filter on the RF (BW 5% or 35 to 45 MHz) so that a 4 MHz is flat and the signal is down 20 dB at 20 MHz offset (I realized I will not be able to measure 10 MHz). I could use a low pass filter on the IF and under this condition I only need four calibrations and measurements. The NFA only has a fixed LO/swept IF or swept LO/fixed IF mode. Not sure how the NFA would be set up. (I do have a call into the Call Center but I figured I would ask here anyway). Any comments (pro's, con's) or new ideas would be greatful. Michael J. Virostko Principal Product Application Engineer Integrated Device Technology, Inc. Westford, MA USA |
1个回答
嗨迈克尔 - 我被告知安捷伦直接回复了你。
希望一切安好 - 以上来自于谷歌翻译 以下为原文 Hi Michael - I am told Agilent has replied to you directly. Hope all is well - |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 21:49 , Processed in 0.654748 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5469
