电子发烧友论坛|
我尝试将LAMEMP3移植到PIC32 MZ DA芯片上,性能相当令人失望。以前的硬件是在1GZ上运行的I.Mx6单核,它运行在小于10%的CPU上运行实况编码器。新硬件使用PIC32 MZ2064 DAH176,它应该具有FPU,etc. Ho。我发现,LAME将花费大约200%的时间来编码单44.1kHz信号。对性能差异有何看法?从臀部猜测说1GHZ/200兆赫=5,所以10%×5是50% CPU,这不是在这里加起来。对LAME代码的剖析显示了许多循环。LAME被设置为从缓存的DDR空间中占大多数。作为参考,闪光灯编码器位于大约10%个CPU,或者每1152个采样周期为700000个。
以上来自于百度翻译 以下为原文 I attempted to port LAME mp3 to a pic32 MZ DA chip, with rather disappointing performance. The previous hardware is an i.mx6 single core running at 1gz, which operates at less than 10% CPU running the live encoder. The new hardware uses the PIC32MZ2064DAH176, which is supposed to have an FPU, etc. However, I find that LAME would take around 200% of real time to encode a mono 44.1khz signal. Any ideas on why the performance difference? Shoot from the hip guess says 1ghz/200mhz = 5, so 10% x 5 is 50% cpu, which isn't adding up here. Profiling the LAME code shows many cycles everywhere.CYCLES 62275 : snd_pcm_read 7680 CYCLES 241 : @lame_encode_buffer_template CYCLES 407477 : lame_copy_inbuffer CYCLES 569180 : Stage 1: vbrpsy_attack_detection CYCLES 96 : Stage 1: vbrpsy_compute_block_type CYCLES 1076469 : Stage 1: LONG BLOCK CASE CYCLES 996 : Stage 1: SHORT BLOCK CASE CYCLES 4367 : Stage 1: short block pre-echo control CYCLES 89 : Stage 1: vbrpsy_apply_block_type CYCLES 560029 : Stage 1: vbrpsy_attack_detection CYCLES 18 : Stage 1: vbrpsy_compute_block_type CYCLES 1075629 : Stage 1: LONG BLOCK CASE CYCLES 757 : Stage 1: SHORT BLOCK CASE CYCLES 4225 : Stage 1: short block pre-echo control CYCLES 54 : Stage 1: vbrpsy_apply_block_type CYCLES 10304 : Stage 1: psychoacoustic model CYCLES 1669433 : @Stage 2: MDCT CYCLES 129 : @Stage 3: MS/LR decision CYCLES 2240782 : @Stage 4: quantization loop CYCLES 29909 : @Stage 5: bitstream formatting LAME is set up to malloc the majority from cached DDR space. As a reference the shine encoder sits at around 10% CPU, or 700000 cycles per 1152 samples. |
8个回答
解码器使用浮标吗?单人还是双人?FPU被禁用了吗?
以上来自于百度翻译 以下为原文 Does the decoder use floats? Single or double? Is the FPU disabled? |
它是一个编码器。它主要使用浮动,32位。我不知道FPU是禁用的,在哪些地方要检查?
以上来自于百度翻译 以下为原文 It is an encoder. It uses primarily floats, 32 bits. I don't know that the FPU is disabled, where are some points to check? |
以下是我最初得到的74个循环129个循环68个周期
以上来自于百度翻译 以下为原文 Here is what I am getting initially SYS_Initialize(NULL); volatile float test1, test2, val1; volatile long double test3, test4, val3, val4; test1 = 1.23456; test2 = 2.34567; test3 = 12345.67891; test4 = 98711223.654321; T1 = _CP0_GET_COUNT(); val1 = test2*test1; T1 = _CP0_GET_COUNT() - T1; PrintUart("%u cyclesrn", T1 - 7); T2 = _CP0_GET_COUNT(); val3 = test3*test4; T2 = _CP0_GET_COUNT() - T2; PrintUart("%u cyclesrn", T2 - 7); T3 = _CP0_GET_COUNT(); val4 = sqrtl(test4); T3 = _CP0_GET_COUNT() - T3; PrintUart("%u cyclesrn", T3 - 7); Yields 74 cycles 129 cycles 682 cycles |
我不太了解M i p s汇编和f p u,但这并不像4循环F pü汇编…map文件显示0x9d079c2c fpMultuulink内存显示1d07y92c2Load地址操作码标签DISASY 288526 1D07Y9C2C 0043DC2αMulsF3 SRL A3,A0,23 288527 1D07Y9C30 30E7000 FFA3、A3、255、288528、1D07Y99405DC2、SRL T1、A1、23、288529、1D07Y9C38 312900FANDI T1、T1、255 288530 288530 1D779C3C 3C0A8000 LUI T2、-32768 288531 1D07Y9C40 00043200 SLL A2、A0 8 8 288532 1D07Y9C44 00 CA3025或A2、A2、T2 288533 1D07Y9C48、SULL TL0、A1、γ1D07Y9C4C 010A402 NDI5或T0,T0,T2,288535 1D07Y9C50 00856026 XOR T4,A0,A1 288536 1D07Y9C54 014C5024和T2,T2,T4 288537 1D07Y9C58 24ECFFF加T4,A3,-1 288538 288538 1D779C5C 2D8100Fe SLTIU AT,T4,254 288539 1D07Y9C60 10200021 BEQ AT,零,CSPA A 288540 1D07Y9C64 00000000 NOP 00000000 1D07Y9C68 252CFFFF Audiu T4,T1,1 288542 1D07Y9C6C 2D8100Fe SLTIU AT,T4,254 288543 1D07Y9C70 10200036 BEQ AT,零,CSPECB 288544 1D779C74 00000000 NOP 288545 1D07Y9C78 0C800 19 Multu0,A2,T0 288546 1D07Y9C7C 00005812 MFLO T3 288547 288547 1D07Y9C80 288547 BEQ T3,零,I17Y1D07Y9C840 MFHI A2 288549 1D07Y9C88 34 C600 01 ORI A2,A2,1 288550 288550 1D07Y9C8C 04C000 00 3BLTZ A2,I18
以上来自于百度翻译 以下为原文 I don't know much about M I P S assembly and the f p u, but this doesn't smell like 4 cycle f p u assembly. .map file shows 0x9d079c2c fpmul Execution memory shows 1d07_92c2 Line Address Opcode Label DisAssy 288,526 1D07_9C2C 00043DC2 __mulsf3 SRL A3, A0, 23 288,527 1D07_9C30 30E700FF ANDI A3, A3, 255 288,528 1D07_9C34 00054DC2 SRL T1, A1, 23 288,529 1D07_9C38 312900FF ANDI T1, T1, 255 288,530 1D07_9C3C 3C0A8000 LUI T2, -32768 288,531 1D07_9C40 00043200 SLL A2, A0, 8 288,532 1D07_9C44 00CA3025 OR A2, A2, T2 288,533 1D07_9C48 00054200 SLL T0, A1, 8 288,534 1D07_9C4C 010A4025 OR T0, T0, T2 288,535 1D07_9C50 00856026 XOR T4, A0, A1 288,536 1D07_9C54 014C5024 AND T2, T2, T4 288,537 1D07_9C58 24ECFFFF ADDIU T4, A3, -1 288,538 1D07_9C5C 2D8100FE SLTIU AT, T4, 254 288,539 1D07_9C60 10200021 BEQ AT, ZERO, CspecA 288,540 1D07_9C64 00000000 NOP 288,541 1D07_9C68 252CFFFF ADDIU T4, T1, -1 288,542 1D07_9C6C 2D8100FE SLTIU AT, T4, 254 288,543 1D07_9C70 10200036 BEQ AT, ZERO, CspecB 288,544 1D07_9C74 00000000 NOP 288,545 1D07_9C78 00C80019 MULTU 0, A2, T0 288,546 1D07_9C7C 00005812 MFLO T3 288,547 1D07_9C80 11600002 BEQ T3, ZERO, i17 288,548 1D07_9C84 00003010 MFHI A2 288,549 1D07_9C88 34C60001 ORI A2, A2, 1 288,550 1D07_9C8C 04C00003 BLTZ A2, i18 |
表19.5.1说明了FPU的一些情况,如果FPU在使用中,应该定义一个宏“SythHuffLoad”…DOC也说它应该在支持它的设备上默认启用。你使用最新的XC32吗?
以上来自于百度翻译 以下为原文 Table 19.5.1 says something about FPU, and a macro "__HARD_FLOAT " should be defined if FPU is in use... Doc also says it should be enabled by default on devices that support it. Are you using latest XC32? |
在我看来,这个设备没有一个FPU。设备的页面说编译器支持FPU,但我认为它只有一个MDU。
以上来自于百度翻译 以下为原文 It appears to me that this device doesn't have an FPU. The page for the devices says the compiler supports the FPU, but I think it only has an MDU. |
对一些愚蠢的原因,MZ…DA没有FPU。只有MZ…EF和MK有一个FPU。
以上来自于百度翻译 以下为原文 Correct. For some stupid reason the MZ..DA doesn't have an FPU. Only the MZ..EF and MK have an FPU. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-1 22:18 , Processed in 0.983826 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1128
