电子发烧友论坛|
嗨,大家,我有一个关于远程配置的问题。
由于我们的实验室只有一块板,我想通过局域网进行远程配置。 我的软件是ise 10.1.03,完整许可证,ic是xc5vsx95t。 连接到服务器计算机的模拟器由xilinx制造。 服务器计算机ip为192.168.0.101,客户端计算机ip为192.168.0.100。 服务器计算机直接连接到客户端计算机。然后,首先:我在服务器计算机上打开C: Xilinx 10.1 ISE bin nt CableServer.exe。 第二:对客户端计算机的开放影响。 第三步:打开电缆设置,将通信模式设置为xilinx u***电缆,将电缆位置设置为远程,将主机名设置为服务器的IP 192.168.0.101。 离开了另一个人。 然后单击确定。 有一个警告: 警告:影响 - 选择的电缆不可用,请选择其他电缆。 有人可以帮帮我吗? 以上来自于谷歌翻译 以下为原文 hi,everyone, i have a problem about remote configuration. since our lab have only one board ,i want to remote configuration by LAN. my software is ise 10.1.03,full license, ic is xc5vsx95t. the simulator which is connect to the server computer is made by xilinx . the server computer ip is 192.168.0.101,the client computer ip is 192.168.0.100. the server computer is connect direct to the client computer. then first: i open C:Xilinx10.1ISEbinntCableServer.exe on the server computer. second: open impact on the client computer. third: open cable setup ,set communicatiom mode to xilinx u*** cable, set cable location to remote, set host name to the server's ip 192.168.0.101. left the other defualt. then click ok. There is an warining: warning:impact-the cable selected is not avaliable,please select a different one. anyone can help me? |
1个回答
在多个论坛中发布相同的问题是没有用的。
在连接Xilinx配置电缆的PC上,您确实说过哪一个,并且您是否已经验证了iMPACT可以与电缆通信? 如果不是,你需要先解决这个问题。 在连接到Xilinx配置电缆和电路板的PC上,启动电缆服务器并尝试连接到它和电路板。 这可能是一个驱动程序问题,可能是其他人已经在使用电缆,可能是多个电缆服务器进程正在运行。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Posting the same question in multiple forums is not helpful. On the PC that is connected the Xilinx configuration cable, you did say which one, and board have you verified that the iMPACT can communicate with the cable? If not you need to fix this first. On the PC that is connected to the Xilinx configuration cable and board, start the cable server and try to connecting to it and the board. It could be a drivers problem, it could be that some else is already using the cable, it could be that multiple cable server process are running. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 05:24 , Processed in 0.882392 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1184
