电子发烧友论坛扫一扫,分享给好友
大家好,我想在使用函数“savePanelImage(UFName,fileName,numColors)”时删除标题栏。
保存的图片将用于单词报告,我不想每次都裁剪它们。 我真的很感激任何帮助 以上来自于谷歌翻译 以下为原文 Hello All, I want to get rid of the title bar when using the function "savePanelImage(UFName,fileName,numColors)". the saved pictures will be used in a word report and i don't want to have to crop them every time. I would really appreciate any help |
3个回答
我不知道在copypanel命令中有任何直接的帮助来解决你的问题,但间接地....在顶部使用没有panelname的面板。
因此,您可能会制作2个功能和2个面板,一个用于您的程序,另一个用于复印或打印。 这样我就可以在打印时克服横向和纵向模式的问题 - 一个面板被组织用于屏幕模式,类似的面板但90度转向被用于在纸上打印..所以也许你不需要顶部的面板名称, 只需在面板属性中删除它,或将其设为空白... 以上来自于谷歌翻译 以下为原文 I am not aware of any direct help to solve your problem in the copypanel command, but indirectly.... Use a panel without panelname at the top. So that perhaps you make 2 functions and 2 panels, one for your program, and one for copying or printing. That way i overcome the problem of landscape and portrait mode when printing- one panel was organized for screen mode, and similar panel but 90 Degree turn was used for printing on paper.. SO perhaps you do not need the panel name at the top, just delete it in properties of the panel, or make it blank... |
60user176 发表于 2019-1-17 15:43 谢谢你的回复,但我没有设法做你的建议,请你举个例子。 以上来自于谷歌翻译 以下为原文 Thank you for your reply, but i didn't manage to do what you have suggested, could you please attach an example. |
让我们反过来:你把你的示例代码放在这里,然后我可以附加更改... 以上来自于谷歌翻译 以下为原文 Lets do it vice versa: you put your sample code here, and i can attach the change then... |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1843浏览 0评论
415浏览 0评论
/9
GMT+8, 2025-12-1 17:16 , Processed in 1.116427 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5185
