电子发烧友论坛|
Health2.04i在一个矩形(容器)中有一个进度条,它在一个具有一个填充的标签的容器的上方,即该层中的顺序是PraseStBaseCuulabLabelCuule.我有进度条上升。另一个容器中的标签位于进度条的一部分之上。这个容器是隐藏的和禁用的。进度条正在填写。当填充到达标签位置时,它似乎停止填充直到标签的另一侧。这些相同的设置在我开发的项目中使用了和谐2.03b,这里没有问题。进度条完全填满了。我用2.03B项目再次验证了这一点。如果我使标签不可见,填充工作,但标签应该是无形的,如果它在一个容器被设置为隐形和禁用。
以上来自于百度翻译 以下为原文 HARMony 2.04 I have a progress bar in a rectangle(container) that's above a container in a layer with a label that has fill enabled, i.e. the order is progres***arContainer labelContainer in the layer. I have the progress bar going up. The label in the other container is over part of the progress bar. This container is hidden and disabled. The progress bar is filling. When the fill gets to the label location, it appears to stop filling until on the other side of the label. These same settings are in the project I developed with Harmony 2.03b and there was no problem here. The progress bar filled completely. I verified this again with the 2.03b project. If I make the label invisible, the fill works, but the label should be invisible if it's in a container that is set to invisible and disabled. |
2个回答
我不确定你说的容器是什么意思。从上面我想说的,你的应用程序的树视图是:Laule0+矩形+进度条+标签容器(无论这可能是什么)++标签:什么是标签容器?
以上来自于百度翻译 以下为原文 I'm not sure what you mean by container. From what I think you are saying above, The tree view of you application is: Layer0 + Rectangle ++ Progress Bar + Label Container (whatever this might be) ++ Label What is the Label Container? |
我研究的是ISO11763系统,它把矩形称为容器。因为这就是他们所能做到的。它们可以包含物品。我使用矩形代替屏幕上的层来对对象进行分组,使它们在一次或不可见和禁用时可见和启用。因此,当我说容器时,我正在谈论矩形。
以上来自于百度翻译 以下为原文 I worked on systems with ISO11783 that referred to the rectangles as containers. Because that's what they can be. They can contain items. I use rectangles in place of layers on a screen to be able to group objects and make them visible and enabled at one time or invisible and disabled. So when I said container I was talking about the rectangle. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 05:17 , Processed in 0.781882 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3292
