电子发烧友论坛|
我尝试将MIC输入连接到BM64模块中,以在电话呼叫期间测试从A2DP配置文件到HFP/HSP的开关的声音质量,并在MIC(作为对讲机模式)拾取噪声的情况下,判断是否有可能自动切换发生。E硬接线模块上的一个面包板(附),以获得一个工作原型,但在芯片上没有地方,我可以找到端口TP1和TP3如建议的参考电路图(也附上)。我的下一步是如何让音频进入芯片,这样它就可以被电话另一端的接收器听到?对此事的任何帮助都将得到极大的感谢。
以上来自于百度翻译 以下为原文 I'm trying to connect a mic input into the BM64 module to test the sound quality of the switch from an A2DP profile to an HFP/HSP during a phone call, and to gauge whether or not it's possible for auto-switching to occur as soon as noise is picked up by the mic (as an intercom mode). Currently, we're hardwiring the module onto a breadboard (Attached) to get a working prototype, but nowhere on the chip can I find the ports TP1 and TP3 as suggested by the reference circuit diagram (Also attached). What should be my next step for getting audio into the chip so that it can be heard by a receiver on the other end of the phone? Any help on this would be greatly appreciated. Thanks Tommy Attached Image(s) |
2个回答
我从未使用过该模块,但我对数据表的阅读表明,BM64引脚位于该示意图右侧(MICYN1,MICYP1,MICROBIAS),因此TP1和TP3必须指示麦克风本身上的引脚,并且您的工作是添加所示的组件。
以上来自于百度翻译 以下为原文 I've never used that module, but my reading of the datasheet indicates that the BM64 pins are on the right side of that schematic (MIC_N1, MIC_P1, MIC_BIAS), so TP1 and TP3 must indicate the pins on the microphone itself, and it's your job to add the components shown. |
您好,我建议您检查BM64评估板的示意图,并将其适配到您的原型.EnrdSPS:使用一个电路板来模拟音频可能无法提供良好的音频结果,因为它们的模拟性能差(触点/盖帽/)…一般建议使用PCB作为音频。原型。
以上来自于百度翻译 以下为原文 Hi, I suggest that you check the schematic of the BM64 evaluation board and adapt it to your prototype. Regards PS : using a breadboard to prototype audio might not give good audio results because of their poor analog performances (contacts / caps / )...generally it is recommended to use PCB for audio prototypes. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:50 , Processed in 0.651156 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2301
