电子发烧友论坛|
嗨,
我想知道是否有一个时钟可以在xilinx中构建,其频率(或周期)可由用户通过一些外部输入(如使用电位计)控制? 米兰 以上来自于谷歌翻译 以下为原文 Hi, I'm wondering if there is anyway a clock can be build in xilinx of whose frequency (or period ) can be controlled by the user via some external input (like using potentiometer)? milan |
1个回答
米兰,
通过使用驱动DDFS的晶体振荡器和改变数字控制字,可以使用直接数字频率合成器(DDFS)作为数控(NCO)。 除了DDFS之外,还有其他种类的NCO。 谷歌“数控振荡器”以及“直接数字频率合成”。 可以在DFS或PLL的反馈路径中选择各种M和D值,因此可以通过固定的小步骤改变频率:32 / 32,31 / 32,30 / 32,29 / 32,28 / 32,27 / 32,...... 1/32。 可能存在一些范围问题,因为最小和最大频率都会使这很困难(但输出必须在32/32和1/32!的规格范围内)。 可以使用电位计来选择输入到A / D转换器(如V5或V6上的系统监视器)的电压(分压器),以产生变化的数字控制字。 或者,只要按住按钮,就可以使用按钮来“递增”或“递减”频率范围。 I DIP开关可用于输入所需的频率,或键盘或键盘。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 milan, One can use a direct digital frequency synthesizer (DDFS) as a numerically controlled (NCO) by using a crystal oscillator driving the DDFS, and varying the digital control word. There are other sorts of NCO, besides the DDFS. Google "numerically controlled oscillator" and also "direct digital frequency synthesis." One can choose various M and D values in the feedback path of the DFS or PLL, so one can vary the frequency in small fixed steps: 32/32, 31/32, 30/32, 29/32, 28/32, 27/32, .... 1/32. There may be some range issues, for both minimum and maximum frequencies that make this difficult, however (the output must be within specification for both 32/32, and 1/32!). One may use a potentiometer to select a voltage (a voltage divider) input to an A/D converter (like the system monitor on V5 or V6) to create a varying digital control word. Or, one may just use push buttons to "increment" or "decrement" the frequency range as long as the push button is held down. I DIP switch could be used to input the frequency desired, or a keypad, or keyboard. Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
3141 浏览 7 评论
3435 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2897 浏览 9 评论
4097 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3081 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1358浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1196浏览 1评论
/9
GMT+8, 2025-12-11 04:56 , Processed in 0.837990 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1223
