电子发烧友论坛|
嗨,我使用的是PNA-X N5244A,但我的问题同样适用于PNA。
现在,我为特定的迹线设置了一些标记。 然后我将该踪迹保存到内存中。 稍后,我用新数据更新该跟踪。 现在,如果我切换到“仅内存”视图,我将获取内存数据的标记值。 但是,当我切换到“数据和内存”视图时,我只会显示“跟踪”的标记值。 是否有办法在“数据和内存”视图中同时在屏幕上显示跟踪和内存的标记? 谢谢,rokEdited:rok于2013年7月31日下午5:13 以上来自于谷歌翻译 以下为原文 Hi, I am using a PNA-X N5244A, but my question can equally apply to PNAs as well. Right now, I have some markers set for a particular trace. I then save that trace into memory. Later on, I update that trace with new data. Now if I switch to 'Memory Only' view, I will get the marker values for the memory data. However, when I switch to 'Data and Memory' view, I only get the marker values showing for the 'Trace'. Is there are way to get the markers to show for both the trace and memory at the same time on the screen in 'Data and Memory' view? Thanks, rok Edited by: rok on Jul 31, 2013 5:13 PM |
10个回答
嗨,你不能用一条痕迹做到这一点。
您需要复制要放置标记的轨迹。 例如,如果我想将标记放在S11存储器轨迹和S11数据轨迹上,我需要在通道中创建2条S11轨迹(请注意,在通道中复制相同的测量值不会增加数据采集时间 )。 我可以将第一个S11跟踪放入内存并选择仅显示内存跟踪,第二个S11跟踪将是我的实时数据跟踪。 现在你可以在两条痕迹上放置标记。 见下图:https://dl.dropboxusercontent.com/u/87949221/MemoryMarker.jpg! 以上来自于谷歌翻译 以下为原文 Hi Rok, you can't do that with a single trace. you'll need to duplicate the trace that you want to put markers on. for example, if I want to put markers both on an S11 memory trace and an S11 data trace, I'll need to create 2 S11 traces in the channel (note that duplicating the same measurement in a channel does not increase the data acquisition time). I can put the first S11 trace into memory and select to display the memory trace only and the 2nd S11 trace will be my live data trace. now you can put markers on both traces. See the picture below: !https://dl.dropboxusercontent.com/u/87949221/MemoryMarker.jpg! |
Topcbpcba 发表于 2019-1-10 17:15 你好,谢谢你的回复。 从显示的图片中,我确实看到橙色迹线,这表明它是基于“记忆”的数据。 但是,标记值颜色仍为黄色。 它们不应该是颜色匹配的吗? (即橙色标记颜色)? 或者你在'数据和记忆'视图中都有它,两者都是相同的,所以它们叠加在一起,但我们只能看到淹没黄色的橙色? 韩国 以上来自于谷歌翻译 以下为原文 Hi, Thanks for the reply. From the shown picture, I do see the orange trace which would indicate it is 'memory' based data. However, the marker value color is still yellow. Shouldn't they be color matched? (i.e. orange marker color)? Or do you have it in 'Data and Memory' view and both are the same, so they are superimposed on top of each other, but we can only see the orange which drowns out the yellow? rok |
> {quote:title = rok写道:} {quote}>嗨,>>谢谢你的回复。 从显示的图片中,我确实看到橙色迹线,这表明它是基于“记忆”的数据。 但是,标记值颜色仍为黄色。 它们不应该是颜色匹配的吗? (即橙色标记颜色)? 或者你在'数据和记忆'视图中都有它,两者都是相同的,所以它们叠加在一起,但我们只能看到淹没黄色的橙色? >> rok Tr1仅显示为内存,因此标记正在读取内存数据,即使标记注释为黄色而非橙色。 我同意如果注释是橙色的,那么混淆会更少,所以我会将这个建议传递给我们的UI设计师。 以上来自于谷歌翻译 以下为原文 > {quote:title=rok wrote:}{quote} > Hi, > > Thanks for the reply. From the shown picture, I do see the orange trace which would indicate it is 'memory' based data. However, the marker value color is still yellow. Shouldn't they be color matched? (i.e. orange marker color)? Or do you have it in 'Data and Memory' view and both are the same, so they are superimposed on top of each other, but we can only see the orange which drowns out the yellow? > > rok Tr1 is being displayed as memory only, so the marker is reading the memory data, even though the marker annotation is yellow and not orange. I do agree that if the annotation was orange, there would be less confusion, so I will pass that suggestion on to our UI designer. |
Topcbpcba 发表于 2019-1-10 17:33 > {quote:title = daras写道:} {quote}> ...所以我会把这个建议传递给我们的UI设计师。 当我告诉我们的UI人员关于颜色问题时,他说他已经注意到了这个问题,并且已经开始研究它了。 它将很快在即将发布的版本中解决。 以上来自于谷歌翻译 以下为原文 > {quote:title=daras wrote:}{quote} > ... so I will pass that suggestion on to our UI designer. When I told our UI guy about the color issue, he said that he had already noticed that problem and had started working on it. it will be addressed in one of the upcoming releases soon. |
很抱歉显示多个帖子,但这不是我的错!
每次我试图回复,论坛一直给我这个'父子密钥错误'(我忘了确切的错误是什么),并没有显示任何更新。 只有在我检查完之后,论坛才开始发布重试积压。 如果我再次遇到论坛错误,我会发布,以便您进一步调查。 rokEdited:jvall于2013年8月1日下午12:15好的,我删除了多个帖子。 不知道为什么会这样 以上来自于谷歌翻译 以下为原文 Sorry for the multiple posts showing, but it's not my fault! Every time I tried to reply, the forum kept giving me this 'parent child key error' (I forgot what the exact error was), and it didn't show any updates. Only later when I checked did it the forum start posting the backlog of retries. If I encounter the forum error again, I'll post it so you can investigate further. rok Edited by: jvall on Aug 1, 2013 12:15 PM OK, I deleted the multiple posts. Not sure why that happened |
嗨再次,只是想跟进我记录的'打印到文件'问题。
我也试过'打印到PDF995'选项,它也有同样的问题。 在pdf中,迹线颜色和标记颜色是青色,当它们应该是深蓝色以指示存储器迹线时。 请注意,我已设置“打印活动窗口”选项。 韩国 以上来自于谷歌翻译 以下为原文 Hi again, Just wanted to follow up on the 'Print to File' issue I noted. I also tried 'Print to PDF995' option, and it also has the same problem. In the pdf, the trace color and marker color are cyan, when they should be dark blue to indicate memory trace. Note that I have the 'Print Active Window' option set. rok 附件 |
蓝色冰汐 发表于 2019-1-10 18:21 print to file有自己的颜色方案,您可以设置。 它可能是颜色方案中的一种颜色为misset。 去打印/打印颜色来查看方案。 默认方案是浅色背景。 我修改了我的暗背景(现在甚至可能是深色背景船作为标准方案)。 然后编辑方案以查看每个属性的颜色。 以上来自于谷歌翻译 以下为原文 print to file has its own color scheme that you can set. It might be that one of the colors in the color scheme as misset. Go to print/print colors to look at the scheme. The default scheme is light background. I modified mine to get dark background (maybe even dark background ships as a standard scheme now). Then edit the scheme to see the colors for each attribue. |
嗨,感谢'打印 - 打印颜色'的建议。
我现在看到问题所在。 出于某种原因,'数据& 每条迹线的限制','记忆','标记'和'记忆标记'设置都设置为相同的颜色! 由于我从未知道这个选项,我认为这是默认设置。 我认为默认颜色方案应该改变以匹配真实颜色在窗口中显示的真实WYSIWYG效果。 否则,在使用默认设置时,您会遇到无法判断打印输出中是否显示数据跟踪或内存跟踪的情况。 韩国 以上来自于谷歌翻译 以下为原文 Hi, Thanks for the 'Print-Print Colors' suggestion. I see where the problem is now. For some reason, the 'Data & Limits', 'Memory', 'Markers', and 'Memory Markers' settings for each trace are set to the same color! Since I never even knew about this option, I assume that this is the default setting. I think the default color scheme should change to match what the true colors are showing in the window for true WYSIWYG effect. Otherwise, you run into the situation where you can't tell whether a data trace or memory trace is showing or not in the printouts when using the default settings. rok |
嗨,我回去重新检查了颜色方案并单击了“重置颜色方案”按钮,只是为了确保在我不知情的情况下没有设置为任意颜色方案。
然后我检查了迹线1到迹线8的“数据”和“记忆”颜色方案。对于迹线1,3到8,它们具有不同的可辨别的颜色来表示“数据”和“记忆”。 仅对于迹线2,它在“数据”和“存储器”之间没有可辨别的色差。 不幸的是,我正在使用Trace 2进行测试,因此我得出结论,所有迹线的所有颜色都以相同的方式设置,而不检查其他迹线编号的颜色方案。 对于那个很抱歉。 因此,我认为只有Trace 2配色方案需要在'Data'和'Memory'类型之间进行更明显的颜色变化。 韩国 以上来自于谷歌翻译 以下为原文 Hi, I went back and re-checked the color scheme and clicked the 'Reset Color Scheme' button, just to make sure it wasn't set to some arbitrary color scheme without my knowing it. I then checked the 'Data' and 'Memory' color schemes for Traces 1 through Trace 8. For trace 1, 3 through 8, they do have different, discernible colors to denote 'Data' and 'Memory'. Only for trace 2 does it not have a discernible color difference between 'Data' and 'Memory'. Unfortunately, I was testing using Trace 2, so I jumped to the conclusion that all the colors for all the traces were set the same way, without checking the color schemes for the other trace numbers. Sorry about that. So, only for the Trace 2 color scheme do I think there needs to be a more distinct color change between 'Data' and 'Memory' types. rok |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 03:16 , Processed in 0.934511 second(s), Total 89, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2880
