电子发烧友论坛|
嗨,我们有一台旧的N9010A频谱分析仪。
我们已经购买了Window7升级版(i7 CPU板)。 今天我们进行了升级。 我们严格按照手册进行。 这是一个漫长的过程,因为我们的设备安装了FW A01.50。 我们使用旧操作系统(XP)对A12.13进行了更新。 更新后,我们导出了工厂校准数据。 然后我们切换到新的CPU板。 首先一切都很好看。 导入出厂校准数据后,设备不再工作。 只有20-60MHz似乎有点 - 其余只是一条没有任何数据的直线。 此外,如果我们执行“全部对齐”手册,则会显示RF校准错误。 工厂恢复磁盘没有帮助。 旧的CPU板显示相同的行为。 随附,您会在更新后找到屏幕图片。 我们可以做些什么才能再次使用分析仪? 非常令人沮丧的是花了很多钱升级并留下了一个不再工作的工具。 Marcus 2.png52.4 KBAlignmentHistory.txt604字节 以上来自于谷歌翻译 以下为原文 Hi, we have got an older N9010A Spectrum Analyzer. We have bought the Window7 Upgrade (i7 CPU Board). Today we performed the upgrade. We did it strictly according to the Manual. It was a lengthy procedure because our device had the FW A01.50 installed. We performed an update to A12.13 using the old OS (XP). After the update we exported the factory calibration data. Then we switched to the new CPU Board. First everything looked good. After importing the factory calibration data the device is no longer working. Only the 20-60MHz seem to be sweeped - the rest is just a straight line without any data. In addition there is an RF calibration error displayed if we do a manual "Align All". A factory restore of the disk did not help. The old CPU board shows the same behaviour. Attached you find a picture of the screen after the update. What can we do to get a working analyzer again ?? Very frustrating having spent a lot of money for the upgrade and being left with an istrument that is not working any more. Marcus 附件
7个回答
嗨马库斯,我和我们的支持工程师谈到了这个......我们将无法通过这个论坛直接帮助你。
这是我们需要与您一对一合作的问题。 您能否联系当地的安捷伦技术联络中心,重新解决此问题? 在美洲,联系信息是:免费电话+1 800 829-4444传真+1 800 829-4433小时美国东部时间上午8:00 - 晚上8:00,周一至周五期待帮助您...... 以上来自于谷歌翻译 以下为原文 Hi Marcus, I spoke to our support engineer about this... We won't be able to directly assist you via this forum. This is an issue we need to work with you one-on-one. Can you contact your local Agilent Technical Contact Center regrding this issue please? In the Americas, the contact info is: toll-free +1 800 829-4444 fax +1 800 829-4433 hours 8:00am - 8:00pm ET, Mon - Fri Looking forward to helping you... |
嗨,谢谢你的回答。
我们在德国,明天我们将联系德国的安捷伦。 我们希望他们能够帮助我们,因为我们没有服务合同! 说实话,整个更新过程根本不起作用,如硬件升级包手册中所述。 由于Windows问题,在XP上更新到A12.13根本不起作用(安装了所需XP SP3的MSXML 6.0 SP2会阻止安装MS SQL Server 2005,这是安装A12.13固件的一部分 EXA)。 这是MS SQL2005的一个已知问题。 我完全不相信安捷伦的测试结果。 仅仅为这个问题找到解决方案花了将近两个小时。 我们的EXA是100%库存 - 到目前为止我们没有安装任何额外的SW。 对于昂贵的设备来说,这是一个非常令人沮丧的经历 - 信号分析仪的成本超过10,000美元,而不是250美元的PC。 马库斯 以上来自于谷歌翻译 以下为原文 Hi, thank you for your answer. We are in Germany, We will contact Agilent in Germany tomorrow. Let's hope they will be able to help us as we do not have a Service contract! To be honest, the whole update procedure was not working at all as described in the Manual of the HW Upgrade package. Updating to A12.13 on XP was not working at all due to a Windows problem (MSXML 6.0 SP2 that was installed with the required XP SP3 prevents the Installation of MS SQL Server 2005 which ist part of the Installation of the A12.13 Firmware for the EXA). That is a known problem with MS SQL2005. I don't believe that this was ever tested by Agilent at all. Finding a solution for this problem alone took us almost two hours. Our EXA was 100% stock - so far we did not install any additional SW. A very frustrating experience for equipment that expensive - that is a Signal Analyzer costing more than 10.000 USD and not a 250 buck PC. Marcus |
您好Marcus - 为了给您乐趣,我找到了您的联系方式... Telefon +49(0)7031 464 6333传真+49(0)7031 464 6336 Servicezeiten Montag bis Freitag von 8 bis 17您在这里是一个电子邮件地址
:德国,CONTACTCENTER(A-Germany,exgen1)我们想提供帮助。 以上来自于谷歌翻译 以下为原文 Hi Marcus - To be helpful, I found this contact information for you... Telefon +49 (0) 7031 464 6333 Fax +49 (0) 7031 464 6336 Servicezeiten Montag bis Freitag von 8 bis 17 Uhr and here is an email address: GERMANY,CONTACTCENTER (A-Germany,exgen1) We want to help. |
谢谢你。
我们明天会看到会发生什么......我会告诉你的。 马库斯 以上来自于谷歌翻译 以下为原文 Thank you for that. We will see tomorrow what happens..... I will Keep you posted. Marcus |
嗨马库斯 - 看看幕后......我可以看到你联系了安捷伦 - 他们已经联系了加州的工厂。
代表您的工作似乎正在进行中。 周末愉快 - 以上来自于谷歌翻译 以下为原文 Hi Marcus - A look behind the scenes... I can see you have contacted Agilent - and they have contacted the factory here in California. Work on your behalf seems to be in progress. Have a nice weekend - |
嗨,与此同时,我们得到了美国安捷伦的答案。
“看起来存在硬件错误,很可能是在A7 Midplane组件上。磁盘驱动器也可能已损坏。中板问题可以解释为什么安装新旧CPU时会出现问题。” 由于这根本没有任何意义,我们坚持认为工厂校准数据存在问题。 因此,我们指示进行Windows XP系统的工厂恢复 - 瞧:一切都在重新开始。 - 没有硬件错误! 现在我们回到原始配置。 看起来从A.01.50到A.13.12的更新会破坏工厂校准数据。 但是,安捷伦的任何人似乎都无法为我们提供该软件的工作更新路径。 因此,我们更失望 - 没有解决方案,但错误的建议将花费我们约1000欧元。 Marcus编辑:IRTrans于2014年4月8日下午3:35 以上来自于谷歌翻译 以下为原文 Hi, in the meantime we got an answer from Agilent in the US. "It appears there is a hardware error, most likely on the A7 Midplane assembly. The disk drive might also be corrupted. A Midplane problem would explain why the problem occurs with both the new and old CPUs installed." As that did not make any sense at all we insisted that there is a problem with the factory calibration data. Therefore we where instructed to do a factory restore of the Windows XP System - and voila: Everything is working again. - No Hardware errror! Now we are back original config. It looks like an update from A.01.50 to A.13.12 destroys the factory calibration data. However, nobody at Agilent seems to be able to provide us with a working update path for the software. Therefore we are even more disappointed - no solution but a wrong advice that would have costed us some 1000 EUR. Marcus Edited by: IRTrans on Apr 8, 2014 3:35 PM |
下一次尝试:在Windows XP上升级到A.06.06版。
结果:校准数据已损坏 - 频谱分析仪再次无用。 很明显,从普通文件到SQL DB的校准数据更新根本不起作用。 安捷伦是否会对此类升级进行任何测试? 经过近两周的时间,仍然没有简单的升级工作解决方案 - 这是荒谬的。 马库斯 以上来自于谷歌翻译 以下为原文 Next attempt: Upgrade to Version A.06.06 on Windows XP. Result: Calibration data corrupted - Spectrum Analyzer useless once again. Obiously the update of the calibration data from plain file to SQL DB is not working at all. Does Agilent do any tests of such upgrades at all ??? After almost two weeks still no working solution for a simple upgrade - that is ridiciulous. Marcus |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:54 , Processed in 0.825788 second(s), Total 54, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1320
