电子发烧友论坛|
您好,我的软件团队有兴趣使用Linux通过各种可能的接口控制测试仪器,如以太网,USB,PXI或AXI。
在5989-6715EN.pdf文档中,它讨论了可在Linux环境中控制的以太网和USB驱动程序和接口。 但是,它没有谈论PXI或AXI,例如M9392A PXI矢量信号分析仪。 我想知道安捷伦是否有一些机制/驱动程序可以通过Linux与PXI或基于AXI的仪器通信? 或者我们是否可以在M9036A PXIe嵌入式控制器上安装Linux? 谢谢,rok 以上来自于谷歌翻译 以下为原文 Hello, My software team is interested in using Linux to control test instruments through a variety of possible interfaces such as Ethernet, USB, PXI, or AXI. In the 5989-6715EN.pdf document, it talks about the Ethernet and USB drivers and interfaces being controllable in a Linux environment. However, it does not talk about PXI or AXI, such as M9392A PXI Vector Signal Analyzer. I wanted to know whether Agilent has some mechanism/driver to talk to PXI or AXI based instruments via Linux? Or whether we can install Linux on a M9036A PXIe Embedded Controller? Thanks, rok |
2个回答
当“信号分析仪”一词出现在标题中时,请在SA论坛中发布;
可能在这里:信号分析仪 - 编程和远程控制:-) 以上来自于谷歌翻译 以下为原文 When the word "signal analyzer" is in the title, please post this in the SA forum; probably here: Signal Analyzers - Programming and Remote Control :-) |
Hi-rok - 除少数高速数字化仪模块(即U1061 / 62A)外,安捷伦不为任何其他PXI或AXI模块或模块化仪器(即M9392A PXI VSA)提供Linux驱动程序。
安捷伦的模块化平台仅正式支持Windows操作系统,而Windows 7 Embedded Standard安装在M9036A PXI嵌入式控制器中。 虽然Linux不支持模块化仪器控制,但Linux可以安装在M9036A PXIe嵌入式控制器上。 但是,M9018A PXIe机箱上的GPIB和触发总线可能无法运行。 M9036A PXIe嵌入式控制器PCI Express端口应该可以运行。 如果Linux安装在M9036A PXIe嵌入式控制器中,建议将Linux安装在与Windows操作系统不同的分区中。 我希望这有帮助 - 以上来自于谷歌翻译 以下为原文 Hi rok - Except for a few high speed digitizer modules (i.e. U1061/62A), Agilent does not provide Linux drivers for any other PXI or AXI modules or modular instruments (i.e. M9392A PXI VSA). Agilent’s modular platforms officially support only Windows operating systems and Windows 7 Embedded Standard is installed in the M9036A PXI Embedded Controller. Although Linux is not supported for modular instrument control, Linux could be installed on the M9036A PXIe Embedded Controller. However, the GPIB and trigger bus on the M9018A PXIe chassis may not be operational. The M9036A PXIe Embedded Controller PCI Express port should be operational. If Linux is installed in the M9036A PXIe Embedded Controller, it is recommended Linux be installed in a separate partition from the Windows OS. I hope this helped - |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 03:43 , Processed in 0.928313 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2009
