电子发烧友论坛|
您好,我有一个自定义C ++应用程序,通过VISA与GPIB与Agilent E4434B对话。
该应用程序运行良好,但我们不得不从使用E4434B切换到E4438C。 在大多数情况下,转变是无缝的。 但是,我们注意到了行为上的差异,每次调查时,两个仪器之间的SCSI命令似乎有点不同。 两个问题:1)我们是否应该将所有SCSI命令升级到E4438C手册中列出的内容? 2)有谁知道这两个发电机之间的SCSI差异是什么? 谢谢 以上来自于谷歌翻译 以下为原文 Hello, I have a custom C++ application that talks to an Agilent E4434B through VISA with GPIB. The application works well however we had to switch from using the E4434B to an E4438C. For the most part the change over was seamless. However, we have noticed off differences in behavior and every time I look into it, it seems that the SCSI commands are just a little bit different between the two instruments. Two questions: 1) Should we upgrade all the SCSI commands to what is listed in the E4438C manual? 2) Does anyone know the what the SCSI differences are between these two generators? Thank you |
2个回答
一个例子是(来自两本手册)E4434B:mem:data:pram:block #ABC E4438C:mem:data:pram:file:bloc“PRAM_DATA”,#14Yq8L
以上来自于谷歌翻译 以下为原文 An example would be (from the two manuals) E4434B :mem:data:pram:block #ABC E4438C :mem:data:pram:file:bloc "PRAM_DATA",#14Yq8L |
Joyalar 发表于 2019-1-8 20:27 嗨 - 与E4438C相比,E4434B的波形结构略有不同。 要成功下载,请参阅编程指南,http://cp.literature.agilent.com/litweb/pdf/E8251-90355.pdf第5节关于下载E443XB信号发生器文件。 问候 - 以上来自于谷歌翻译 以下为原文 Hi - The E4434B waveform structure is slightly different compared to the E4438C. To download successfully, please refer to the Programming Guide, http://cp.literature.agilent.com/litweb/pdf/E8251-90355.pdf section 5 on Downloading E443XB Signal Generator Files. Regards - |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 20:23 , Processed in 0.760320 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1503
