我曾尝试在我的windows8发布预览系统上安装所有版本的Xilinx ISE作为管理员。
我在Windows 7操作系统的兼容模式下运行此程序,Windows8支持windows7的兼容模式,同样适用于XP和Win7。 错误显示:setup.exe已停止工作。 windows很快就会发现它 我咨询了微软reg,他们建议联系Xilinx。 是不是xilinx兼容windows8 RP? 以上来自于谷歌翻译 以下为原文 I had tried installing all the versions of Xilinx ISE as administrator on my windows8 release preview system . I have Run this program in compatibility mode for Windows 7 operating system,Windows8 supports compatibility mode of windows7,the same is working on XP and Win7. error shown: setup.exe has stopped working. windows will find it out soon I have consulted Microsoft reg the same, they suggested to contact Xilinx. is'nt xilinx compatible for windows8 RP? |
45个回答
哦好的,我得到了它遵循这个解决方案
http://www.xilinx.com/support/answers/44397.html 谢谢 以上来自于谷歌翻译 以下为原文 Oh Ok I got it followed this solution http://www.xilinx.com/support/answers/44397.html Thanks |
有没有人试图在Windows 8上安装Xilinx 14.7?
我有几个类型的错误: ProjectMgmt:387 - TOE:ITclInterp :: ExecuteCmd给出了Tcl结果'无效命令名“_GetPropertyType”'。 两者都有32位和64位ISE版本。 有没有人知道如何解决这个问题? 非常感谢, - 毛罗 以上来自于谷歌翻译 以下为原文 Does anyone have tried to install Xilinx 14.7 on Windows 8 ? I'm having several errors of the type: ProjectMgmt:387 - TOE: ITclInterp::ExecuteCmd gave Tcl result 'invalid command name "_GetPropertyType"'. Both with 32 and 64 bit ISE versions. Does anyone have an idea on how to solve the issue ? Many thanks, - Mauro. |
嗨,你什么时候遇到这个问题?
如果在打开旧项目时看到问题,原因可能是项目损坏。 尝试创建一个新项目。 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, When are you encountering this issue? If the issue is seen while opening a old project, the cause may be due to corrupt project. Try creating a new project. Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
dinardo写道:
有没有人试图在Windows 8上安装Xilinx 14.7? 我建议你在这里搜索一下。 这个问题已经被问过并回答了大约125次。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 dinardo wrote:I suggest you do a search here. This question has been asked and answered about 125 times. ----------------------------Yes, I do this for a living. |
这也是我面临的问题。
我尝试安装ise 13.1并且具有完全相同的问题。 _xsetup.exe停止工作。 请帮忙。 以上来自于谷歌翻译 以下为原文 This is the problem I am facing too. I tried installing ise 13.1 and have the exact same issue. _xsetup.exe stops working. Please help. |
点击链接。
问题解决了。 http://binarykoala.blogspot.com/2013/10/get-xilinx-ise-146-webpack-to-work-on.html?showComment=1396640583410 以上来自于谷歌翻译 以下为原文 Follow the link. problem solved. http://binarykoala.blogspot.com/2013/10/get-xilinx-ise-146-webpack-to-work-on.html?showComment=1396640583410 |
粒子,
我想表达我的谢意! 我只花了最后2个小时来解决这个问题并最终卸载/重新安装Vivado和ISE几次,然后绊倒你的修复程序,第一次尝试完美无缺。 路要走!!! 拯救我的生命,一次一条评论,哈哈。 --Wonderwill 以上来自于谷歌翻译 以下为原文 particle, I would like to extend my thanks! I just spent the last 2 hours troubleshooting this issue and ended up uninstalling/reinstalling Vivado and ISE several times before stumbling upon your fix, which worked flawlessly on the first try. Way to go!!! Saving my life, one comment at a time, lol. --Wonderwill |
感谢您提出这些建议,他们对我非常有帮助。
我能够使用libPortability.dll替换技巧运行ISE。 Planahead仍在我身上坠毁,但我相信我找到了解决方案。 它在启动GUI时失败了,我收到了其他人报告的Java错误。 与其他修复程序一样,该解决方案似乎强制它以32位加载。 编辑文件:C: Xilinx 14.7 ISE_DS PlanAhead bin loader.bat 在loader.bat文件中查找此部分代码: set RDI_OS_ARCH = 32if [%PROCESSOR_ARCHITECTURE%] == [x86](如果定义了PROCESSOR_ARCHITEW6432(设置RDI_OS_ARCH = 64))else(如果定义了PROCESSOR_ARCHITECTURE(设置RDI_OS_ARCH = 64)) 并注意第一个之后的所有行,如下所示: 设置RDI_OS_ARCH = 32rem如果[%PROCESSOR_ARCHITECTURE%] == [x86](rem如果定义了PROCESSOR_ARCHITEW6432(rem set RDI_OS_ARCH = 64rem)rem)else(rem如果定义了PROCESSOR_ARCHITECTURE(rem set RDI_OS_ARCH = 64rem)rem) 这使得Planahead能够推出,到目前为止一直运作良好。 希望这有助于其他试图在Windows 8中使用Xilinx的人。 干杯, 弗兰克张 以上来自于谷歌翻译 以下为原文 Thank you for these suggestions, they were very helpful to me. I was able to get ISE running with the libPortability.dll replacement trick. Planahead still crashed on me, but I believe I have found a solution. It was failing at the point where it starts the GUI, and I was getting the Java error others have reported. The solution, like the other fixes, seems to be forcing it to load in 32-bit. Edit the file: C:Xilinx14.7ISE_DSPlanAheadbinloader.bat Look for this section of code in the loader.bat file: set RDI_OS_ARCH=32 if [%PROCESSOR_ARCHITECTURE%] == [x86] ( if defined PROCESSOR_ARCHITEW6432 ( set RDI_OS_ARCH=64 ) ) else ( if defined PROCESSOR_ARCHITECTURE ( set RDI_OS_ARCH=64 ) ) And remark out all the lines after the first one, like so: set RDI_OS_ARCH=32 rem if [%PROCESSOR_ARCHITECTURE%] == [x86] ( rem if defined PROCESSOR_ARCHITEW6432 ( rem set RDI_OS_ARCH=64 rem ) rem ) else ( rem if defined PROCESSOR_ARCHITECTURE ( rem set RDI_OS_ARCH=64 rem ) rem ) This allowed Planahead to launch and so far has been working fine. Hope this helps others who are trying to use Xilinx in Windows 8. Cheers, Frank Cheung |
尽管有时候还没有工作,但还有很多其他的工作......相比之下......与Xilinx相比,这是一个很大的进步。
所以,弗兰克的贡献很大。 以上来自于谷歌翻译 以下为原文 Despite sometimes is not working, many other works...which is a great advance compared to...nothing up to now besided Xilinx. So, great contribution Frank. |
虽然使用libportabilityNOSH.dll适用于ISE,但这不是PlanAhead的选项,因为它直接链接SmartHeap。
但是,Vivado 2014.1和更新版本正式支持Windows 8,仍然使用SmartHeap。 这意味着已在Vivado 2014.1+中针对Windows 8更新了SmartHeap DLL。 我们可以通过将ISE 14.7附带的SmartHeap DLL替换为来自Vivado的DLL来完全解决问题。 如果ISE安装在C:驱动器的默认路径中,则附加脚本将自动执行此操作。 如果没有,请修改脚本顶部的路径以指向正确的位置。 我真的希望Xilinx向ISE推出一个补丁来实现这一目标。 它不应该花费太多精力,并且会使它在近两年的操作系统上运行。 希望这很有用! Xilinx_Win8_fix.zip 163 KB 以上来自于谷歌翻译 以下为原文 While using libportabilityNOSH.dll works for ISE, this is not an option for PlanAhead as it directly links SmartHeap. However, Vivado 2014.1 and newer officially support Windows 8, and still use SmartHeap. This means the SmartHeap DLLs have been updated for Windows 8 in Vivado 2014.1+. We can fix the issue completely by replacing the SmartHeap DLLs that come with ISE 14.7 with those from Vivado. The attached script will do this automatically if ISE is installed in the default path on the C: drive. If not, modify the path at the top of the script to point to the proper location. I really hope Xilinx pushes out a patch to ISE that does this. It should not take much effort and would make it work on an operating system that's nearly two years old. Hope this is useful! |
我能够通过在nt设置中执行相同的安装过程让xilinx在8.1上工作,但我无法下载到任何主板,因为它无法找到有线驱动程序。
有解决方案? 以上来自于谷歌翻译 以下为原文 I was able to get xilinx to work on 8.1 by following the same process of installing in the nt setup, however I cannot download to any boards for it can't find cable drivers. Any solutions? |
我尝试在Windows 8上安装ISE 11.1,但是当我双击xsetup.exe时,它根本就不运行。
现在呢? (我刚从Xilinx网站上下载并解压缩,没有烧录DVD)。 以上来自于谷歌翻译 以下为原文 I try to install ISE 11.1 on Windows 8, but when i double click on xsetup.exe, it simply don't run. And now what ? (I just downloaded it from Xilinx website and unzip it, without burning on DVD). |
这只是一般性评论,但我正在尝试使用较旧的Spartan FPGA进行项目。
我的电脑运行Windows 8.1。 我只有麻烦,所以我放弃了。 这个帖子已经存在了两年,而ISE仍然不支持Windows 8.我不能使用PlanAhead,因为一些未知的原因,你不能使用PlanAhead制作Coregen DCM模块 - 只有ISE(我不得不谷歌 为什么我不能让Coregen在PlanAhead中制作DCM。 真是一团糟! 以下是我对Xilinx的印象: “你有一个新的操作系统,但是想开发更旧的硬件吗?SCREW你!” 不,我现在不是一个大批量的客户。 我是一个“爱好者”,晚上在家里玩得很开心,但我的日常工作是使用我的MSEE为一家知名公司设计定制硅片。 现在,想出如何在一些毫无防备的傻瓜上卸载我的三个或四个Xilinx FPGA板,并获得一些Altera板,他们知道如何制作有效的软件。 是的,我很生气。 我浪费了几个小时试图让ISE模拟器工作 - 我本来可以用来设计我的设计,或者花时间陪伴我的妻子和孩子。 “Windows 8是一个新的操作系统”借口两年前运作良好,但现在已经不复存在了。 Virtex和斯巴达设备对Vivaldo的支持是否真的很难? 我开始使用Virtex 2开始制作FibreChannel显示板。几年前,我正在使用Virtex 5为网络设备制作ASIC原型(感谢内置的SERDES)。 Xilinx,它很有趣,但我觉得你对我们的关系缺乏承诺。 对不起咆哮,但我只是厌倦了撞墙试图使用这些愚蠢的FPGA。 下次我购买FPGA板时,它不会来自我所知道的公司,只要他们愿意,就会放弃支持。 以上来自于谷歌翻译 以下为原文 This is just a general comment, but I am trying to do a project with a older Spartan FPGA. My computer runs Windows 8.1. I have had nothing but trouble, so I am giving up. This thread has been around for TWO YEARS, and still ISE does not oficially support Windows 8. I can't use PlanAhead because, for some unknown reason, you cannot make Coregen DCM modules using PlanAhead -- only ISE (and I had to google why the hell I could not have Coregen make a DCM in PlanAhead). What a mess! Here is my impression of Xilinx: "You have a new OS, but want to develope for older hardware? SCREW YOU!" No, I am not a high-volume customer right now. I am a "hobbyist" having fun at home in the evenings, but my day job is to use my MSEE to help design custom silicon for a well-known company. Now, to figure out how to unload my three or four Xilinx FPGA boards on some unsuspecting fool and get some Altera Boards, where they know how to make software that works. Yes, I am pissed. I wasted several hours trying to get the ISE simulator to work -- time that I could have been using to work on my design, or spend time with my wife and kids. The "Windows 8 is a new OS" excuse worked well two years ago, but not any more. Would it REALLY be that hard to shoe-horn support for Virtex and Spartan devices into Vivaldo? I got my start making a FibreChannel display board using a Virtex 2. A few years ago, I was prototyping an ASIC for a network device using a Virtex 5 (thanks for the built-in SERDES). It was fun while it lasted, Xilinx, but I sense your lack of commitment to our relationship. Sorry for the rant, but I am just tired of banging by head against the wall trying to use these stupid FPGAs. The next time I buy an FPGA board, it will NOT be from a company that I know will drop support whenever they feel like it. |
D235J的解决方案适合我。
似乎在胜利8.1下修复了14.7错误的一切......谢谢! 法案 以上来自于谷歌翻译 以下为原文 D235J's solution works for me. Seems to have fixed everything that was wrong with 14.7 under win 8.1... Thanks! Bill |
Thanksd235j。
尽管有针对ISE修复的所有建议。 我发现在Windows 8上对EDK(xps)的任何帮助都很困难。我手动尝试了可移植性修复,但没有解决它。 你的神奇修复让一切顺利。 遗憾的是,在xilinx标准安装结束时无法添加该脚本。 它会为很多人节省很多麻烦。 再次感谢。 以上来自于谷歌翻译 以下为原文 Thanks d235j. Despite all the suggestions of fixes for ISE. I found it difficult for any help with EDK(xps) on Windows 8. i manually tried the portability fix but that didn't fix it. Your magical fix made everything work. Shame that that script couldn't of been added at the end of the standard install from xilinx. It would of saved a lot of people a lot of hastle. Thanks again. |
修复很棒。但是,请确保在没有空格的路径中解压缩,否则批处理文件将失败。
以上来自于谷歌翻译 以下为原文 The fix is great. However, be sure to unzip it in a path with no spaces or the batch file will fail. |
大家好。
请帮助我..我得到了由d235j发布的tdownload zip文件,但我没有得到它,我必须放在哪里,我应该保存...我得到的错误 _pn.exe已停止工作 以上来自于谷歌翻译 以下为原文 Hey guys. please help me.. i got tdownload zip file posted by d235j but i am not getting it that where i have to place and where i should save... and i am getting error of _pn.exe has stopped working |
只有小组成员才能发言,加入小组>>
3115 浏览 7 评论
3405 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2870 浏览 9 评论
3961 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3055 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1324浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1166浏览 1评论
/9
GMT+8, 2025-12-1 10:47 , Processed in 1.083002 second(s), Total 79, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1574
