电子发烧友论坛|
MSO9000系列示波器上的AUX输出位于设备背面,有时在执行偏斜校准时难以访问。
我的问题是:Q1)E2655偏移校正夹具直接应用于AUX BNC输出有多重要? Q2)校准高速探头时,AUX输出和E2655偏移校正夹具之间是否可以使用短(0.5米或更短)的BNC电缆? 以上来自于谷歌翻译 以下为原文 The AUX output on the MSO9000 series oscilloscopes is located on the back-side of the unit which is sometimes difficult to access when performing skew calibration. My question is this: Q1) How critical is it that the E2655 deskew fixture get applied directly at the AUX BNC output? Q2) Can a short (0.5-meter or less) BNC cable be applied between the AUX output and the E2655 deskew fixture when calibrating high-speed probes? |
1个回答
您应该能够使用短BNC电缆,没有任何问题。
我在工厂支持中谈到了这一点,这里是信息的要点:如果你想这样做,没问题,只要认识到如果你在一个通道上使用电缆进行歪斜校准,而在另一个通道上进行歪斜校正 电缆,2个通道不会排队。 顺便说一下,我从未进行过“官方”偏斜校准。 我主要使用串行总线,触发器的位置无关紧要。 所有测量都在通道之间进行。 我通过将它们放在相同的信号上来调整相对于彼此的通道,并在通道对话框中调整偏斜。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 You should be able to use a short BNC cable with no problems. I spoke to factory support about this and here's the gist of the message: If you want to do this, no problem, just recognize that if you do a skew cal on one channel with the cable, and a skew cal on another channel with out the cable, the 2 channels won't line up. BTW, I never do an 'official' skew calibration. I'm mostly working on serial buses, and the location of the trigger doesn't matter. All measurements are made between channels. I deskew the channels relative to each other by putting them both on the same signal, and adjusting the skew in the Channel dialog. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 04:11 , Processed in 0.696186 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1496
