亲爱的团队请指教。
如何从目录D: iRCT Software CarrierPower Picpower.PNG中删除原始文件? 当我尝试使用命令“execute close”和“System.IO.File.Delete(path)”从目录中删除文件时; ,程序发生错误为附件。 请参阅我为您提供的图表参考。 你能告诉我示例命令吗? 以上来自于谷歌翻译 以下为原文 Dear Team Please advice. How can I delete an original file from the directory D:iRCT SoftwareCarrierPowerPicpower.PNG? When I try to delete file from the directory with command “ execute close” and “System.IO.File.Delete(path)”; , the program occurred error as attach file. Please see diagram that I made for you reference. Could you please let me have the example command? 附件
1个回答
我认为您遇到的问题是您尝试使用两种不同的方式来访问同一个文件。
如果您正在使用To / From File对象来读取/写入文件,只需使用带有EXECUTE DELETE的To File,您无需先关闭它,因为无论如何VEE都独占使用它。 HTH,迈克 以上来自于谷歌翻译 以下为原文 I think the problem you have is that you are trying to use two different ways to access the same file. If you are using To/From File objects to read from /write to the file simply use a To File with EXECUTE DELETE, you don't need to close it first because VEE has exclusive use of it anyway. HTH, Mike |
只有小组成员才能发言,加入小组>>
1070 浏览 0 评论
2306 浏览 1 评论
2093 浏览 1 评论
1967 浏览 5 评论
2838 浏览 3 评论
841浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
616浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
716浏览 0评论
1398浏览 0评论
1071浏览 0评论
GMT+8, 2024-9-30 13:08 , Processed in 1.223496 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
