扫一扫,分享给好友
亲爱的各位,我正在用PIC16F18323开发一个项目。我想用UART TX/RX功能来发送和接收数据。当然,我必须使用PPS将TX/RX函数与适当的输入/输出引脚相关联。不幸的是,我在手册中找不到PPS输出引脚的值,将它与TX函数联系起来。我想使用RA4作为TX传输,所以我应该WRI。TE:(我通过互联网阅读下面的语句)Ra4ppsBist.Ra4PPS= 0x014;//RA4--G.EuSART:TX;但是在手册中,我读到0x014被描述为“保留”。可能有些问题:您能帮我解决这个问题吗?非常感谢您的帮助和合作。
以上来自于百度翻译 以下为原文 Dear all, I'm developing a project using PIC16F18323. I want to transmit and receive data using UART TX/RX feature. Of course I have to use PPS to associate TX/RX function with proper input/output pins. Unfortunately I can't find in the manual the value of PPS output pin to associate it to TX function. I want to use RA4 as TX transmission so I should write: (I read the following statement over internet) RA4PPSbits.RA4PPS = 0x0014; //RA4->EUSART:TX; but in the manual I read that 0x0014 is described as 'Reserved'. Maybe something is wrong: could you help me to fix the problem ? Thank you very much for your help and cooperation regards |
5个回答
我想他们用Rev C打破了数据表。如果你看看Rev A,它显示TX是0x14。你有没有尝试过硬件的0x14,看看它是否有效?
以上来自于百度翻译 以下为原文 I think they broke the data sheet with rev C. If you look at rev A, it shows TX is 0x14. Have you tried 0x14 with hardware to see if it works? |
亲爱的Javple,我在修订C(7/2017)数据表,PAG 145文档代码:DS400 01799 C上读到它
以上来自于百度翻译 以下为原文 Dear jtemples, I'read it on Revision C (7/2017) datasheet, pag 145 document code: DS40001799C |
我没有尝试硬件,因为我还在开发它。我必须使用手册的Rev A吗?
以上来自于百度翻译 以下为原文 I didn't try with hardware because I'm still developing it. Do I have to use REV A of the manual ? |
也许你可以试试MCCHe说:
以上来自于百度翻译 以下为原文 Maybe you could try MCC He says: bool state = (unsigned char)GIE; GIE = 0; PPSLOCK = 0x55; PPSLOCK = 0xAA; PPSLOCKbits.PPSLOCKED = 0x00; // unlock PPS RXPPSbits.RXPPS = 0x05; //RA5->EUSART:RX; RA4PPSbits.RA4PPS = 0x14; //RA4->EUSART:TX; PPSLOCK = 0x55; PPSLOCK = 0xAA; PPSLOCKbits.PPSLOCKED = 0x01; // lock PPS GIE = state; |
只有小组成员才能发言,加入小组>>
5255 浏览 9 评论
2038 浏览 8 评论
1958 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3219 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2268 浏览 5 评论
796浏览 1评论
689浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
618浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
687浏览 0评论
587浏览 0评论
GMT+8, 2024-12-31 01:28 , Processed in 1.250779 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
