电子发烧友论坛扫一扫,分享给好友
在尝试下载Vivado时,会出现有关“导出合规性警报”的错误消息。
为什么这个问题发生在埃及? 我想几年前我们没有遇到过这样的问题。 这个问题很快就会解决吗? 我真的希望如此。 谢谢 以上来自于谷歌翻译 以下为原文 While trying to download Vivado, there is an error message about "export compliance alert". Why does this issue occur in Egypt ?. I think few years ago we did not face such a problem. Will this issue be solved soon? I really hope that. Thanks |
6个回答
嗨@ sherif123
由于严格的出口管制政策,不再可能在某些E或D类别国家/地区创建或维护在线帐户。 请参阅以下答案记录。 http://www.xilinx.com/support/answers/44043.html 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @sherif123 Due to strict export control policy, it is no longer possible to create or to maintain an online account in some E or D category countries. Refer to the following answer record. http://www.xilinx.com/support/answers/44043.html Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
是的,我对我的国家了解这一点。
这个问题很快就会得到解决吗? 我们应该忘记在这里使用Xilinx芯片吗? 以上来自于谷歌翻译 以下为原文 Yes I knew this about my country. Will this issue be resolved soon? Should we forget about using Xilinx Chips here? |
嗨@ sherif123
请尝试联系最近的销售/分销商办事处以获取更多信息 http://www.xilinx.com/about/contact.html 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @sherif123 Try contacting your nearest sales/distributor office for more information. http://www.xilinx.com/about/contact.html Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
最近负责非洲的经销商证实他们不卖给埃及。
那么这个问题很快就会解决吗? 我怎样才能找到任何一个负责此问题的人? 经销商没有帮助。 以上来自于谷歌翻译 以下为原文 Recently the distributor responsible for africa confirmed that they don't sell to Egypt. So will this issue be solved soon? How can I reach any one responsible for this issue?. The distributor does not help. |
嗨@ sherif123
这些限制基于美国出口法规,Xilinx无法控制这些限制。 您可以尝试联系法律部门http://www.xilinx.com/legal.htm 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @sherif123 These restrictions are based on US export regulations and Xilinx has no control on those restrictions. You may try contacting the legal department http://www.xilinx.com/legal.htm Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我最近从Digikey购买了一块板,由Digilent制造的Zybo Zynq-7000,包含Xilinx XC7Z010-1CLG400C芯片。
但是,当我试图获得免费版Vivado来操作我的主板时,我收到以下消息:“导出合规性验证失败”。 我现在卡在我的电路板上,无法使用它。 我住在埃及,没有任何限制获得董事会,所以我怎么能得到必要的软件来使用它。 请指教。 以上来自于谷歌翻译 以下为原文 I recently bought a board from Digikey, Zybo Zynq-7000 manufactured by Digilent and contains the Xilinx XC7Z010-1CLG400C chip. However, when I tried to get the free version of the Vivado to operate my board, I received the following message: "Failed Export Compliance Verification". I am now stuck with my board and cannot make any use of it. I am living in Egypt and there was no restriction whatsoever getting the board, so how come I am not able to get the necessary software to use it. Please advise. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 10:31 , Processed in 0.690843 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1578
