嗨,我正在使用带有BenchLink Waveform Builder Pro的33500B进行一些序列加载。
我创建了一个具有两个梯形脉冲的单通道波形。 一个从0变为2v并返回到0.另一个变为负0到-1v并返回到0v。 我将它发送到单位,它报告的偏移量为500mV,但它正如你所期望的那样播出,两个脉冲以0v为中心。 但是,现在,如果我创建一个只有两个相同波形的序列并将其播出,它会将偏移设置为-500mV,这就是它如何播放我想将这个发生器连接到一些高功率放大器和一个偏移量 高会炸毁负载有谁知道这些补偿发生了什么? 谢谢 以上来自于谷歌翻译 以下为原文 Hi, I am using a 33500B with BenchLink Waveform Builder Pro to do some sequence loading. I have created a single channel waveform which has two trapezoid pulses. One goes from 0 to 2v and back to 0. The other goes negative 0 to -1v and back to 0v. I sent it to the unit and it reports an offset of 500mV but it plays out as you would expect, the two pulses centered around 0v. However, now if I create a sequence which is just two of the same waveform and play it out, it sets the offset to -500mV and that's how it plays out I want to hook this generator up to some high powered amplifiers and an offset that high will blow up the load Does anyone know what is going on with these offsets? Thanks |
1个回答
嗨如果将来有人正在寻找这个问题:我的代表是“操作错误”你必须确保High&
当您将数据发送到设备时,“波形/序列参数”组框中的低级参数是对称的。 您创建的波形将缩放为这些值,如果它们是不对称的,您将得到偏移的干杯 以上来自于谷歌翻译 以下为原文 Hi In case anyone else in the future is searching for this problem: It turned out to "operating error" on my behalf You have to make sure that the High & Low level parameters in the "Waveform/Sequence Parameter" group box are symmetric when you send the data to the unit. The waveforms you create are scaled to these values and if they are asymmetric you get an offset Cheers |
只有小组成员才能发言,加入小组>>
1287 浏览 0 评论
2375 浏览 1 评论
2194 浏览 1 评论
2064 浏览 5 评论
2951 浏览 3 评论
1115浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
754浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
928浏览 0评论
1288浏览 0评论
GMT+8, 2024-12-24 17:36 , Processed in 1.766935 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
