电子发烧友论坛|
我正在使用E5071c,我正在尝试获得S参数测量。
我使用“SENS:SWE:POIN 200”将扫描点数设置为200,并执行“CALC:PAR:DEF S21”进行S21测量。 然后我使用“CALC1:DATA:FDATA?”读取数据。 我正在使用python套接字来获取流。 我遇到的问题是我使用while循环得到“socket.recv(1024)”的数据数组只有大约20个数据点。 不是200.我试过改变数据点的数量,我的阵列中仍然可以获得大约18-20个数据点。 我尝试绘制数组并将其与VNA显示进行比较,它看起来像是一个非常近似的情节。 我收到的数据没有足够的数据点。 有解决方案? 谢谢 以上来自于谷歌翻译 以下为原文 I am using the E5071c and I am trying to obtain S-parameter measurements. I set the number of sweep points to 200 using "SENS:SWE:POIN 200" and do "CALC:PAR:DEF S21" to do the S21 measurement. Then I read the data using "CALC1:DATA:FDATA?". I am using python sockets to get the stream. The problem I have is that the data array I get "socket.recv(1024)" using a while loop has only around 20 data points. Not 200. I have tried changing the number of data points and I still get around 18-20 data points in my array. I tried plotting the array and comparing it to the VNA display and it seems like a very approximate plot. The data I get back does not have enough data points. Any solutions? Thank you |
1个回答
虽然我通常使用PNA而不是ENA,但我强烈怀疑您在尝试读取数据时可能处于连续扫描模式?
如果是这样,我希望这是问题所在。 当分析仪仍在忙于扫描和更新数据时,您无法读取完整扫描的数据。 您需要触发扫描,以便在读取数据之前触发器进入空闲状态(保持)。 我相信用于触发单次扫描的正确ENA命令是INIT {ch}:IMMediate或TRIG:SEQuence:SINGle.Edited:bhokkan于2014年3月22日上午3:44 以上来自于谷歌翻译 以下为原文 Although I normally work with PNAs rather than ENAs, I strongly suspect you may be in Continuous Sweep mode while you are trying to read the data? If so I expect that is the issue. You can't read a full sweep's worth of data while the analyzer is still busy sweeping and updating the data. You need to trigger a sweep such that the trigger goes into idle (hold) afterward before you read the data. I believe the proper ENA commands to choose from for triggering a single sweep are INIT{ch}:IMMediate or TRIG:SEQuence:SINGle. Edited by: bhokkan on Mar 22, 2014 3:44 AM |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 13:47 , Processed in 0.746375 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6256
