我有一个PIC16C620A,我发现PigIt 3不支持它(在有人试图学习微控制器的第一步上的一个挫折……太棒了)我怎么能在面包板上烘烤一块开发板呢?显然,我不能花800块钱在一个官方的(PM3)开发板上。把这个价格除以80,结果比我愿意支付的要多。一组由PICIT支持的图片有这样一个价格问题:我应该在VDD和VSS之间读取5V,而PICIT没有上传程序。M?
以上来自于百度翻译 以下为原文 I have a PIC16C620A, and I found out Pickit 3 doesn't support it (A setback right on the first step of someone trying to learn microcontrollers... just great) How can I bake a development board on a breadboard ? Evidently, I cannot spend 800 bucks on an official (PM3) development board. Divide that price by 80 and the result is more than I'm willing to pay - A set of dozen of Pickit supported PICs have that price Side question: Should I be reading 5V between VDD and VSS while pickit is not uploading a program ? |
8个回答
你为什么要尝试使用这个设备来学习微控制器?这是古老的,正如你所发现的,它是不受目前的程序员从微芯片支持。如果你有一个窗口版本,你需要一个紫外线来擦除它。如果你不,那么芯片只能编程一次。我假设这是一个打字,你的意思是“使”不是“烘烤”。我不确定我是否理解你在问什么。所以,得到一个支持PIC的PIC。只有当你已经设置了PK3来为设备提供电源(这是一个可选的设置),即使这样,MPLAB工具栏上还有一个按钮让你关掉电源。
以上来自于百度翻译 以下为原文 Why would you try to use that device to "learn about microcontrollers? It is ancient, and as you have found, it's not supported by the current programmers available from Microchip. If you have a windowed version, you need a UV light to erase it. If you don't, then the chip can only ever be programmed once. I assume that'e a typo, and you meant "make" not "bake". I'm not sure I understand what you are actually asking. So, get a PICkit supported PIC. Only if you have set the PK3 to supply power to the device (this is an optional setting), and even then, there is a button on the MPLAB toolbar that lets you turn that power off and on. |
谢谢你的答复,了解不同的销售…新的…C.…集合的美是在各种各样的,我认为大小是相当适合我的功能在心里如何告诉?我想我能找到这样的点亮,我会在上传前几天模拟程序,以防所有这些问题都解决,制作程序板太难了吗?
以上来自于百度翻译 以下为原文 Thank you for the answers To learn different things Old... New... C... assembly The beauty is in the variety And I think the size is quite appropriate for the function I have in mind How to tell ? I think I can find such light If not, I'll simulate the program for days before uploading In case all these problems are dealth with, is it too hard to make the required programming board ? |
在新的设备中有很多种类,这些程序更容易编程。认真地,去做所有的努力只是为了设计一个多年来不被推荐为新设计的设备,这只是浪费时间。我保证你可以找到一个更便宜、更好的零件。看看芯片,看看它是否有一个透明的窗口,让你看到里面。
以上来自于百度翻译 以下为原文 There's plenty of variety in newer devices that are much easier to program. Seriously, going to all that effort just to program a device which has been "not recommended for new designs" for years is just a waste of time. I guarantee you can find a cheaper, better part in the same or smaller size. You look at the chip, and see if it has a transparent window that lets you see inside. |
“去做所有的努力只是浪费时间”同意…垃圾桶的新芯片(有两个)是不可擦除的
以上来自于百度翻译 以下为原文 "going to all that effort just a waste of time" Agree |
如果你想要一些STMOS,一些2764,一些PIC16C765和更多的新东西发送到垃圾箱…只要问一下(不,实际上,只有几个是幸运的!)
以上来自于百度翻译 以下为原文 If you want some STmicros, some 2764, some PIC16C765 and more new stuff to send to the bin... just ask here (No, actually, only a few ones are "brand new..." luckily!) |
如果运费不是价值的两倍,我就买你的货……让我难过的是看不到好的硬件。
以上来自于百度翻译 以下为原文 I'd buy those from you if the shipping wasnt twice their value... Saddens me to see good hardware unused |
我也喜欢保留我所有的“年龄”。然后张贴照片
以上来自于百度翻译 以下为原文 I like to keep some pieces of all of my "ages" as well. Should post a photo then |
在16C的日子里,你会买一个1000美元的冰块和500美元的POD来调试一个设计。编程是一个PIC开始加上(你仍然可以在易趣网上)。加窗的芯片价格昂贵,需要紫外线消除器半小时。新的Flash芯片解决了擦除问题。并且内置调试减少了对ICE的需求。如果你想成为老学校和便宜。试试PIC16F87A,它将与PICTIT3一起工作。但你唯一会学到的是,过去很难编写一个PIC。
以上来自于百度翻译 以下为原文 Back in the 16C days you would buy a $1000 ICE and $500 pods to go with it to debug a design. Programing was a pic start plus( that you can still get on eBay). Windowed chip where expensive and you needed the uv eraser and a half hour. The new flash chips solved the erasing issues. And built in debugging reduced the need for an ICE. If you want to be old school and cheap. Try a PIC16F877A. It will work with a PICKit3. But the only thing you will learn is it was harder to program a pic in the past. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
454 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3529 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
466浏览 0评论
/9
GMT+8, 2025-12-1 17:48 , Processed in 0.816662 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3272
