嗨,
如何通过硬件管理器找到我连接的设备的确切部件号? 我只能找到与设备系列对应的通用名称,我希望接收完整的部件号,如下所示 xczu9eg-ffvb1156-2-I-ES1 Avi Chami MScFPGA网站 以上来自于谷歌翻译 以下为原文 Hi, How can I find the exact part number of a device I am connected to via Hardware Manager? I am able to find only a generic name that corresponds to the device family, I would like to receiver the complete part number as in xczu9eg-ffvb1156-2-i-es1 Avi Chami MSc FPGA Site |
13个回答
你好@ a_chami,
硬件管理器仅显示没有包的零件名称。 如果您正在尝试检查设计的哪个部分,则可以检查位文件头。 因此,请打开您的位文件,并在那里找到必要的信息。 希望这可以帮助。 问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @a_chami, Hardware Manager only shows he part name without package. If you are trying to check what part a design was made for you could check in the bit file header. Therefore, please open your bitfile and the necessary info can be found there. Hope this helps. Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
嗨@anatoli,
感谢您的答复。 我不想知道位文件上的设备,我想知道放在板上的设备如何识别自己。 Avi Chami MScFPGA网站 以上来自于谷歌翻译 以下为原文 Hi @anatoli, Thanks for your response. I don't want to know the device on the bitfile, I want to know how the device placed on a board identifies itself. Avi Chami MSc FPGA Site |
你好@ a_chami,
请在配置板上询问此问题,而不是“安装和许可”,因为配置板是解决此类问题的正确论坛板。 Config专家将就此提供建议。 亲切的问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @a_chami, Please ask this question on the Configuration board rather than "Installation and Licensing", as the Configuration board is the right forum board for such questions. The Config experts will be able to advice you on this. Kind Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
+ @a_chami
你好@hpoetzl, 感谢您的信息,但下面是您使用这些命令得到的信息。 但是,即使你有基于用户指南的hex值,你所得到的只是部分,而不是包。 请参阅下面的示例(此示例使用UG570)。 但是我不认为这是@ a_chamiis正在寻找的东西。 因此,我不认为这在Vivado硬件管理器中是可能的,但我可能是错的,所以这就是为什么我要求@ a_chamito在配置板上问这个问题。 亲切的问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 + @a_chami Hello @hpoetzl, Thanks for the info, however the below is what you'd get using these commands. However, even if you have the hex value, based on the User Guide, all you'd get for this is the part, not the package. See my example below (UG570 was used for this example). However i don't think this is what @a_chami is looking for. Therefore, i don't think this is possible in the Vivado Hardware Manager, but i could be wrong, so that is the reason why i've asked @a_chami to ask this questions on the Configuration board instead. Kind Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
@a_chami,
如果您打算访问这些信息并阅读可通过JTAG读取的内容 - DNA,IDECODE,用户ID代码等, - 您可以在HDL代码中实例化BSCAN原语 - 或者在7系列中实现BSCAN2 - 并尝试获取 IDCODE返回被测设备的完整信息 - 我想为每个设备提供一个独特的32位寄存器! 有关更多信息,请查看UG470。 希望这会有所帮助, 侯赛因 以上来自于谷歌翻译 以下为原文 @a_chami, If you are going to get access to such information and read what can be read via JTAG - DNA, IDECODE, USER ID codes, etc.,- you can instantiate BSCAN primitive inside your HDL code -or BSCAN2 in 7series - and try to get the IDCODE which returns the complete information of the device under test - a uniqe 32 bit register I think for every device!. Take a look at the UG470 for more information. Hope this will help, Hossein |
@hpoetzl,@ anatoli,@ embedded
谢谢你的回答。 我正在寻找一种方法来检索完整的部件号。 我知道这在某种程度上是可行的,因为当我过去尝试加载带有ES1位文件的ES2设备时,我收到一条错误消息。 IDCODE是否有不同的ES1 / ES2编号,以及商业/工业等其他参数? 如同anatoli建议的那样,我也在配置板中发布了这个问题 Avi Chami MScFPGA网站 以上来自于谷歌翻译 以下为原文 @hpoetzl, @anatoli, @embedded Thanks for your answers. I am asking for a way to retrieve the complete part number. I know that this is possible in some way, since when I have tried in the past to load an ES2 device with an ES1 bitfile I receive an error message. Does the IDCODE have different numbers for ES1/ES2, and for other parameters like Commercial/Industrial... etc? BTW as anatoli suggested, I have also posted this question in the Configuration Board Avi Chami MSc FPGA Site |
@a_chami,
就Xilinx而言,它肯定是可能的,因为它是JTAG链检测设备的方式。 请看下面的UG470 p170: 希望这会有所帮助, 侯赛因 以上来自于谷歌翻译 以下为原文 @a_chami, As far as Xilinx states it is definitely possible because it is the way your JTAG chain can detect the device. Take a look at below from UG470 p170: Hope this will help, Hossein |
你好@ hpoetzl @ a_chami,
据我所知,这个AR表明这个独特的IDCODE适用于每个家庭成员。 这并不意味着包裹。 这里根本没有提到包裹。 而@ a_chamiis正在寻找Vivado硬件管理器的零件+封装信息,而不仅仅是零件。 问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @hpoetzl @a_chami, From what i understand, this AR indicated that this unique IDCODE is for each part family member. That doesn't mean the package. The package isn't mentioned here at all. Whereas @a_chami is looking for part + package information from Vivado Hardware Manager, not just the part. Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
感谢@ hpoetzl。
我的理解也是一样的。 实际上,让我们看看配置专家可以就此问题提出什么建议。 顺便说一句,这是在配置板上发布此问题的链接:https://forums.xilinx.com/t5/Configuration/Get-Hardware-part-number-using-Hardware-Manager/m-p/786123#M6439 再次感谢,祝你有个美好的夜晚。 亲切的问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Thanks @hpoetzl. My understanding would be the same. Indeed, let's see what the config experts can suggest on this matter. BTW, here is the link where this question was posted on the Configuration board: https://forums.xilinx.com/t5/Configuration/Get-Hardware-part-number-using-Hardware-Manager/m-p/786123#M6439 Thanks once again and have a nice evening. Kind Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2180 浏览 7 评论
2617 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2213 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
452浏览 1评论
1541浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2184浏览 0评论
516浏览 0评论
1658浏览 0评论
GMT+8, 2024-5-14 20:18 , Processed in 1.487886 second(s), Total 104, Slave 87 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
