大家好,我来这里给你;
因为我需要你的帮助才能使我的VEE程序与U2781机箱和两个U2531A DAQ测量卡配合使用。 截至今日; 我使用的是模块化机箱U2781和两个U2531A 2MHz数据采集卡。 但是,我无法使用U2781机箱完全同步数据采集卡(U2531A)。 事实上,到目前为止,我正在使用“DAQ v Tools”预配置的VEE User_Function,从两个U2531A卡中获取数据,非同步。 但是,配置User_Function的那些不允许主/从定义。 我当时决定,从sratch重新启动并仅使用SCPI语言和VEE功能重建我的程序,但此时我已经结束了。 这就是为什么,我就以下问题向你致敬。 您建议采用什么方法来解决此问题? 碰巧知道,如果有预建的程序可以满足我的需求吗? 我期待你的回复。 先谢谢你。 真诚的塞巴斯蒂安 以上来自于谷歌翻译 以下为原文 Hello Everyone, I coming here to you; because I need your help to make my VEE program work with the U2781 chassis and two U2531A DAQ measurement card. As of today; I am using a modular chassis U2781 and two U2531A 2MHz Data Acquisition cards. However I am unable to fully syncronized both Data Acquisition cards (U2531A) using the U2781 chassis. As a matter of fact, Up to today, I was using "DAQ v Tools" pre-configured VEE User_Function, to acquire Data, Non-Syncronized, from both U2531A cards. However those configured User_Function do not allow Master / Slave definition. I decided then, to restart from sratch and rebuild my program using only SCPI Language and VEE function, but I am coming onto an end at this point. This why, I am coming onto you regarding the following matter. What approach do you recommend to solve this problem? Do happen to know, if there are pre-built programs outhere for my needs? I look forward you replies. Thank you in advance. Sincerely Sebastien |
1个回答
嗨塞巴斯蒂安,我认为对你的信息缺乏回应的原因是你不容易理解你需要什么。
我建议如果你有特定的问题,例如 有一个你无法控制的功能然后询问。 如果您想讨论更一般的主题,请务必问但我不确定“您建议采用什么方法来解决这个问题?” 给出了足够的关于上下文的线索。 例如,如果您试图将仪器操作转换为SCPI,那么您可以问这一点,尽管具体示例可能会有所帮助。 是你遇到麻烦的同步吗? HTH 以上来自于谷歌翻译 以下为原文 Hi Sebastien, I think the reason for the lack of response to your message is that it is not easy to understand what you need. I would suggest that if you have a specific problem e.g. there is a function you cannot control then ask about that. If you'd like to discuss a more general topic, by all means ask but I'm not sure "What approach do you recommend to solve this problem?" gives enough of a clue as to the context. If, for example, you are trying to convert an instrument operation into SCPI then you could ask just that, although again a specific example might help. Is it the synchronisation you're having trouble with? HTH |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 03:38 , Processed in 0.592443 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1392
