多次尝试安装Vivado webpack。
还尝试将驱动器从C:改为D: 安装的最后一步是“下载文件时出错”。 并提示是/否。 两个都试过不行。 请调试附加的日志文件。 此外,我重新格式化了我现有的笔记本电脑并完成了新的win os安装 但是,同样的问题 xinstall_1458790849837.log 22 KB 以上来自于谷歌翻译 以下为原文 Tried several times to install Vivado webpack. also tried changing drive from C: to D: While last step in installation it says "Error downloading files". and prompt for yes/no. both tried not working. Please debug attached log file. Also, i reformatted my existing laptop and done fresh win os installation But, the same issue xinstall_1458790849837.log 22 KB |
8个回答
嗨,您使用的是网络安装客户端吗?您可以尝试下载Vivado Design Suit单文件下载吗?-Shreyas
-------------------------------------------------- --------------------------------------------尝试搜索你的答案 在发布新帖子之前在论坛或xilinx用户指南中发出问题。请注意 - 如果提供的信息解决了您的问题,请将答案标记为“接受为解决方案”。给予您认为有用的帖子给予荣誉(右边提供的星号) 并回复.---------------------------------------------- ------------------------------------------------ 以上来自于谷歌翻译 以下为原文 Hi, Are you using web install client? Can you try downloading Vivado Design Suit Single file download? -Shreyas---------------------------------------------------------------------------------------------- Try to search answer for your issue in forums or xilinx user guides before you post a new thread. Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query. Give Kudos (star provided in right) to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
您好@dhruvkumaarpatel
你尝试过新的下载吗? 提出下载请求@ http://www.xilinx.com/support/service-portal.html 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @dhruvkumaarpatel Did you try with a fresh download? Raise a downaload request @ http://www.xilinx.com/support/service-portal.html Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
@vijayak。
我执行了新的下载请求。它说它不是公司地址,因为我来自大学。但是,我的请求已被接受 以上来自于谷歌翻译 以下为原文 @vijayak. I performed fresh download request. It says its not corporate address as i am from university. However,my request has been accepted |
您好@dhruvkumaarpatel
你的SR号码是多少? 你有没有从支持团队那里听到回复? 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @dhruvkumaarpatel What is your SR number? Did you hearback from the support team? Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
@dhruvkumaarpatel,
以下是下载Vivado的方法: 来自Xilinx下载网站(这里) 来自答案记录#65995 使用Link请求Viavdo 2015.4的DVD 我已经通过电子邮件发送了Ezmove的Vivado 2015.4完整下载文件。 https://ezmove.xilinx.com/ --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @dhruvkumaarpatel, The below are the ways to download Vivado:
https://ezmove.xilinx.com/ --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
嗨!
你分享了这个庞大的~10 Gb文件。 我只是想使用web安装客户端来实现FPGA目的。在这里,我从下载页面再次下载了这个文件:Xilinx_Vivado_SDK_2015.4_1118_2_Win64.exe 现在,我输入了dhruvkumaarpatel和密码的用户名。 它让我通过了第一步,当我走到最后一步时,它再次问我相同的凭据。 登录名和密码已自动填写。 我刚点击'登录'。 这不是让我走得更远。 在我重新输入所有细节之后。结果是一样的! 所以,我认为它的身份验证问题。 所以,这一次,请终于审查我的案例并向我展示完美的方式。 我正在分享附加的屏幕截图和几个日志文件以及我的解决方案的详细信息。 我的用户名:dhruvkumaarpatel 电子邮件:1503011709@svuca.edu 目的:测试& 测量[大学实验室] 大学:硅谷大学 软件要求:Vivado Web安装[Windows 10免费版64位] xinstall_1458850785605.log 24 KB xinstall_1458850375535.log 56 KB xinstall_1458790849837.log 22 KB xinstall_1458790155950.log 23 KB xinstall_1458789718671.log 38 KB 以上来自于谷歌翻译 以下为原文 Hi! You shared the big bulky ~10 Gb file. I just want to use web install client for the FPGA purpose.Here, I downloaded again from the download page this file : Xilinx_Vivado_SDK_2015.4_1118_2_Win64.exe Now, I entered my username as dhruvkumaarpatel and password . It let me pass the first step and when I came to the last step it again asked me same credentials. The login and password were auto filled . I just clicked 'login' . It was not letting me move further. after I reentered all the details.The result is same! So, I think its the problem of authentication. so, this time, kindly review my case finally and shows me the perfect way. I am sharing the attached screenshot and several log files plus my details for your ease of the solution. My username: dhruvkumaarpatel Email : 1503011709@svuca.edu Purpose : Test & Measurement [university lab] University : Silicon Valley university Software requirement : Vivado Web install [Free edition of 64-bit for windows 10] xinstall_1458850785605.log 24 KB xinstall_1458850375535.log 56 KB xinstall_1458790849837.log 22 KB xinstall_1458790155950.log 23 KB xinstall_1458789718671.log 38 KB |
您好@dhruvkumaarpatel
您的个人资料似乎存在问题。 您是否可以尝试登录http://www.xilinx.com/support/download.htmland在此处分享您尝试从xilinx.com下载时发出的错误消息? 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @dhruvkumaarpatel It looks like there is an issue with your profile. Can you try logging in to http://www.xilinx.com/support/download.html and share the error message here that you ecnounter when you try to download from xilinx.com? Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我可以轻松下载安装文件!
但是在安装它的同时要求在最后一步输入用户名和密码。那时候它还没有到下一步。我也可以在xilinx.com上输入我的电子邮件和密码。 以上来自于谷歌翻译 以下为原文 I can easily download setup file! but while installing it asks to enter username and password in the last step.that time it doesn't go to next.also,I can enter my e-mail and password on xilinx.com with success. |
只有小组成员才能发言,加入小组>>
2369 浏览 7 评论
2785 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2251 浏览 9 评论
3328 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2419 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
740浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
529浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
342浏览 1评论
746浏览 0评论
1947浏览 0评论
GMT+8, 2024-11-13 06:23 , Processed in 1.348508 second(s), Total 91, Slave 74 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
