电子发烧友论坛|
你好论坛,我在我的项目中使用LIN芯片进行通信。芯片我用它在5V稳压器输出格式。但我没有得到5V的稳压器输出引脚,而不是得到1V。
以上来自于百度翻译 以下为原文 hello forum, I am using LIN chip in my project for communication. The chip I am using it in 5V regulator output format. But I am not getting 5v a regulator output pin instead of that am getting 1V. thanks to all Regards Cha1312 |
7个回答
对不起,你的问题没有翻译成英文。你能展示一下你的电路原理图和你的问题的更多细节吗?
以上来自于百度翻译 以下为原文 Sorry, your question has not survived translation into English. Can you show a schematic of your circuit, and more details of your problem? |
此外,XC32编译器论坛是询问此类问题的最佳场所。
以上来自于百度翻译 以下为原文 Moreover, the XC32 Compiler forum is the best place to ask such questions |
看一看这个数据表:我假设,在用“某物”为VBAT供电之后,VReg没有放出适当的VCC,例如3.3或5V(一看不清楚)。LIN引脚过载?糟糕的PCB?
以上来自于百度翻译 以下为原文 Took a look at this datasheet: I assume that, after powering VBat with "something", VReg is not letting out a proper Vcc such as 3.3 or 5V (not clear at a glance). So... overload at LIN pins? bad PCB? |
你现在的Vbat是什么?我建议使用12 V的电流限制不小于1 A。收发器能够提供70毫安,因此过载不应该是一个问题(虽然你永远不知道除非你测量)。
以上来自于百度翻译 以下为原文 What is your current Vbat? I'd suggest to use 12 V with a current limit not smaller than 1 A. The transceiver is capable to deliver 70 mA, thus overload should not be an issue (although you knever know unless you measure). |
你好论坛,谢谢你宝贵的建议和时间。我找到了解决问题的办法。在与VBAT串联的电阻中存在一个小问题。更换10欧姆电阻后,能看到调节器的输出,也能看到输出。
以上来自于百度翻译 以下为原文 hello forum, thanks for your valuable suggestions and time. I got the solution for my problem. There was a small problem in the resistance which is connected in series with vbat. After replacement it with 10 Ohm resistance am able to see output at regulator and also in lin. thank you all Regards cha1312 |
你好论坛,我需要你的帮助,我面临的另一个问题。如何将MCP2025与PIC32 MX550F256L接口,没有与LIN相关的CPU寄存器的信息,LIN在第一页的数据表中只提到一次,既不支持LIN,也请帮助我。
以上来自于百度翻译 以下为原文 hello forum, I need your help for one more problem which I am facing. How to interface mcp2025 with pic32mx550f256l. There is no information of CPU registers related to LIN, LIN is mentioned only once in datasheet at first page, neither Harmony supports LIN, kindly help me. |
首先获得一个3.3伏输出的MCP2025,例如PIC32家庭参考手册,SeCT。21 UART数据表-并尝试了解。对不起-没有应用笔记,这种衍生物随时可用。但是,在微芯片主页上搜索Pic32和Lin的一些应用说明。继续将PIC32的UART中的一个对应的位连接到MCP。然后,只有一些“软件”来写。基本上,连接PIC16没有什么区别。虽然这将需要一些努力,以使PIC32和运行…
以上来自于百度翻译 以下为原文
Basically, it is not much different from connecting some PIC16. Although it will require some effort to get the PIC32 up and running... |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
495 浏览 0 评论
5808 浏览 9 评论
2347 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3542 浏览 3 评论
1152浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1118浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
886浏览 1评论
499浏览 0评论
/9
GMT+8, 2025-12-11 20:08 , Processed in 0.861259 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1517
